1 Member and 45 Guests are viewing this topic.
Jason
A954BC,N700BW,20297,Bombardier BD-100-1A10 Challenger 300,Borgwarner Inc
Don't any longer Terry
paul tricker
These were up & about today, one I have found info about..
* 4017C1  GAWPZ                                                      2017/01/14 11:53:49
G-AWPZ   Andreasson BA4B   c/n1   J. M. Venning
* 684170  HV    7                                                        2017/01/14 09:28:19
I suspect a mis-code, but no idea of what, (I had to google the country!)
It climbed from 16300--33000
Paul
CYYZGUY
40" LED Monitor
40" LED Monitor
Hi Paul
4017C1,G-AWPZ,1,Andreasson BA-4B,John Martin Vening
No idea on your other
Good morning Alan, Saturdays unknowns:
3C5EFD (2x) nothing more
3FF3CC  DMDUS D-MDUS was and mabye still is an  AutoGyro Europe Calidus 912ULS / Is it possible, that D-MDUS is an AutoGyro Test reg? If yes maybe it shoeld be addded as that.
Have a nice Sunday!
Regards Ingo
Morning Ingo
3C5EFD, doesn't decode.  Sequence finishes at 3C5EFA D-AGWZ and starts again at 3C5F01 D-AGXA so looks like a corrupt packet from a Germwanwings A319
3FF3CC,D-MDUS,C00353,AutoGyro Calidus  I have no idea if it was or is still a test registration
Many thanks
Morning Terry, many thanks
Chris11
Hi Alan
008045 ZS-ACA - Owner Stratair (Pty) Ltd
Not sure if you are aware that the SACAA is now publishing an online list of aircraft. The search does not work well and it is very clunky. http://www.caa.co.za/Lists/Aircraft%20Register/AllItems.aspx
Chris
Chris11
.... and another one
00865D ZS-CKA Owner Fireblade Investments Ltd
Chris
Many thanks Chris, I will bookmark the register
Morning Alan/Jason,
Regarding reply #8920, according to the Canadian register, N989CM Cessna 182T c/n 18281358 is now registered C-GISE to E Master Ltd.
Thanks for that Ian, it is in under its correct hex of C060E3 so miscode added
