0 Members and 28 Guests are viewing this topic.
Evening Alan, todays unknown from  HD area:
48C5E6  SRN689, SRN: Sprintair, http://www.airfleets.net/ficheapp/plane-atr-488.htm
Regards Ingo
Evening Ingo
48C5E6,SP-SPG,488,Aerospatiale ATR 72-202,Sprintair,
Kenny
880865 HS-BCE Diamond DA42 c/n 42.365  ex OE-VPI, OE-FYB  op Bangkok Aviation Center
Kenny
ANRB 3km north of VTBD
X
PS Приволжское translate to Privolshskoy which is an area somewhere near the Volga and Росавиации translates to  Rusaviatsii.
X
chris
Hi Alan.
Many thanks for the reply, maybe better luck with next request when I have one.
Regards.
Chris.
X
This normally populates so do not know why it did not today, has it changed reg and still using old box or is it a second use?
142331  RA09009                                                        2017/01/27 15:02:00
X
X
Two SU95's were at SVO today in the Sukhoi corporate gold c/s but uncertain if this was one of them, as from the height I lost it at, it was probably VKO it went to. However you have it marked as miscoding whereas after my email the other day I believe 1F7AED is its correct ex factory code and not 117AED as stated in db.....but which c/n I have no idea as there have been a few 97005's.
* 1F7AED                           97005      SU95  Sukhoi Design Bur... 2017/01/27 12:05:00
* 1F7AED  LX9317                   97005      SU95  Sukhoi Design Bur... 2017/01/27 16:15:26
X
No idea if it was in previously but it was new in November
142331,RA-09009,264,Dassault Falcon 7X
Regarding 1F7AED, the main thing is the hex details the aircraft concerned.  97005 is the 4th prototype and I have no idea what it used when first flown.
What was the other one at SVO that was gold coloured.
Good Evening Alan, Thursday unknowns:
3D2D75  DEPLT finally: https://planefinder.net/data/aircraft/D-EPLT
3E7F75  DKNLT http://de.flightaware.com/photos/view/329173-b07a5a8da6a22a1b1825a919eed061de2b926221/all/sort/date/page/1/size/fullsize
MILs:
* 3E8640  COBRA3                                                         2017/01/26 12:50:06
* 3E8640  TORO2                                                          2017/01/26 17:49:26
* 3E9536  GAF833                                                         2017/01/26 09:30:44
* 3E9743        2017/01/26 08:37:50
* 3E9CD6        2017/01/26 12:34:51
   3EA41E  SNIPR44                                                        2017/01/26 17:42:16
* 3EACD5  HG01B                                                          2017/01/26 17:17:08
* 3F6B7B  STONE                                                          2017/01/26 12:54:45
   3F6E0F  COBRA1                                                         2017/01/26 12:49:14
   3F6E0F        2017/01/26 17:40:45
* 3F8CFE        2017/01/26 17:41:23
* 3F8CFE  SNIPR41                                                        2017/01/26 18:15:45
   3FB1BA  TA203                                                          2017/01/26 13:08:17
   3FB1BA        2017/01/26 13:56:37
* 3FBE0D  APOLLO                                                         2017/01/26 10:02:40
* 3FBE0D        2017/01/26 14:40:39
Regards Ingo
Evening Ingo
3D2D75,D-EPLT,2002546,Van's RV-7
3E7F75,D-KNLT,12-003,Stemme S 12
Mil tac added
Many thanks and have a good weekend
X
#8773
Hi Alan
RA-09009 is a new frame as you state, the old one was 7X c/n 47. That explains that one!
The two Su95's at SVO were white bodied with gold tail with Sukhoi in white and a gold wave style coachline under the windows. Both were snow covered and impossible to read off but due to the snow covering I do not think either was 97005. (I believe they were most likely RA-89004 and 7). About 10 Aeroflot versions were also parked up at the hangars but also impossible to read off.
PS I thought the fourth prototype was the one W/O in Indonesia (frame 95004). Frame 5 c/n 95005 was also dinged in Keflavik.
X
You may be correct X, only going by my d/b
