0 Members and 26 Guests are viewing this topic.
Michel
Alan,
CFG1ML GCRR-EDDH
CFG3DL EDDH-GCLP
RYR21HX EGSS-EPRZ
TFL343 EHAM-MDPC
Michel
Good morning Alan, Fridays unknowns:
3D0BED  DECTP (2x) Reims Cessna FR172H Rocket Mk1EB June 2nd 2016 flugzeugforum.de
http://www.flugzeugforum.de/threads/79477-Flugbetrieb-in-Muenster-Telgte-EDLT/page8?p=2315529
3D10D0  DEEPS no active airframe found
MILs:
* 3F75B2        2017/01/27 08:39:24
* 3F75B2  GAF123                                                         2017/01/27 15:51:42
* 3FB70B  GAF009                                                         2017/01/27 08:01:31
3FF362  ZZZZZZZZ still nothing on this one
3FF482  DMRVT (2x) possibly a Rotorvox C2A
Have a nice day!
Regards Ingo
Morning Ingo
3D0BED,D-ECPT,,Reims FR172H Rocket
Nothing on your others and mil tac added
Many thanks
X
#8780
This should be RA-42401 YK42 operating for UTair, it must be back from being UP-Y4203 where it was in storage in Almaty.
* 14A5A1  UT9751                                                         2017/01/27 18:26:37
* 14A5A1  UT9707                                                         2017/01/27 22:54:47
* 14A5A1        2017/01/27 23:20:55
According to Russian register it was reregistered RA-42401 3rd Oct16
X
Morning Alan,
EC-LST ATR 72 c/n 234 of Swiftair is operating for Air Europa.
VLG6216 : LIRF-GCTS  (The return of VLG6217 is already in the d/b).
LLX5267 : ESSA-LEAL
LLX5266 : LEAL-EFHK
X
#8782
Picked up today
* 15067F        2017/01/28 12:12:45
15067F decodes to RA-67199 however I found two references on the net, one for RA-67199 a Cessna 172 and the other to RA-67199 Let410 of Avia Express (however it is actually UR-67199) and both references are recent so I assume the Cessna and the Russian register agrees!
X
X
#8783
PS I have sent you a link to the russky register, which should keep you busy as there about 1000 Mil's!
X
Hi X
Got your email thanks
14A5A1,RA-42401,452042116567,Yakovlev Yak-42D,Turukhan Avia
15067F,RA-67199,172S11384,Cessna 172S Skyhawk SP
Many thanks
X
I trust the list helps you with a few unknowns from this part of the world....whether or not they ping is another story but should keep you busy....now I have to find the FLARF register! RF- I doubt will be available with all the VVS/Govt aircraft carrying RF- reg's these days.
X
M
NTJ553   ESNL   ESSA   via ESNK
NTJ661H   ESUT   ESSA   via ESNV
Typo
ABFF5D is N872SJ (not N827SJ)
