0 Members and 37 Guests are viewing this topic.
X
1F7AEB 97003 SU95 has just departed Zhukovsky, operator not noted but assume that 1F**** means still with Sukhoi OKB. No prefix 97003 was one of the prototypes and did carry 95003 at one time which was its c/n but cannot confirm if it is the same c/n today.
X
No idea X, I presume its the same one but not easy to find out otherwise
I have them in as the trustee/Netjets Sales as usual without c/o as per normal
Hi Alan, one unknown MIL/TAC in HD today:
3EAD91  SMASH32
Regards Ingo
Cheers Terry, thanks again
Terry,
ZR401 was added in at 1626 and its with BAe Systems at this time does not become Oman - Air Force until delivery when its hex and serial will change.
Thanks Terry,  However N217CB was not already in the d/b but I have now entered the data
Terry,
N217CB was deleted From the database as the frame is now N227SL added as such 20/1 and N217CB was deleted at the same time.
Things change in no time!!
CYYZGUY
40" LED Monitor
40" LED Monitor
Terry,
If you look up N217CB on the FAA you will note that there is a pending number change to N227SL.  I caught N227SL on the network and made the change.  The owner is authorised to make the change and the FAA does not make the change to their database until the owner notifies them it is done.  This notification can sometimes take a good deal of time after it has been done, quite archaic to say the least. and the aircraft can be flying around under its new guise for weeks, months before the change is notified and the database updated
Good morning Alan, Mondays unknowns:
MIL: 3F54E1
401080 (2x) decodes G-DKMK but nothing about an active aircraft.
Regards Ingo
