0 Members and 15 Guests are viewing this topic.
X
This one I reported previously appears to be VP-BWG A319 Rossiya hex 400155 miscoding regularly.
400157        2017/02/14 20:55:44
X
Morning Terry, many thanks
Morning X added it in as a miscode.  Can you advise if you also got 400155 at the same time
Morning Alan,
French AF A340 F-RAJB c/n 81. Accompanying photo is not an A340. Can you please do the necessary at your end.
Alan,
Might have to scrub that. Just looked in the photo folder and it does show an A340 although that didn't come up. Strangely, the photo that did come up isn't in the folder under F-RAJB.
Not populating :
020056
X
I picked up 400155 either side of 400157, same flight SDM number was in the c/s box.
X
X
Must be crew training going on at Ostafyevo today, as I have three aircraft in continuous circuits all miscoding 300327 I-EASW, ABCDEF is/was N86QU c/s 13345 and A580B3 RA-01932 (last one in the db as such, was ex N4538B).
I also had unknown A580B7 earlier at 900ft
X
Cheers X, looks like a one box miscode
Nothing on your Moroccan Ian
X
I-EASW is an AgustaWestland Test Registration which has been used on 10 or so A139's bit I cant see any with a Russian connection
ABCDEF look like a spurious hex with no connection to N86QU
RA-01932 is in the d/b with the miscode and its correct hex of 14078C
A580B7 is the hex for Ce185 N4538F which is current on the FAA list.  However given the proximity to the miscode of RA-01932, could it be another B429 miscoding
Afternoon Alan,
3E82C2  GAF031  Tactical ?
VLG4002 : LIRN-LEMD
VLG4003 : LEMD-LIRN
LLP8233 : LIRN-LEMD
LLP8234 : LEMD-LIRN
I suspect these are one-off charters for the Real Madrid v Napoli game therefore not sure if you want to include or not.
Afternonn/Evening Alan todays unknowns from HD area:
* 072097  R72097                                                         2017/02/15 10:04:57
* 072097  R72097                                                         2017/02/15 13:21:25
both times below 6000ft and 300+ message count
* 3D0FD1  DEEFX https://planefinder.net/data/aircraft/D-EEFX and http://www.flugzeug-bild.de/bild/flugplaetze~deutschland~bonn-hangelar-edkb/93086/mooney-m20l-pfm-porsche-flugmotor-d-eefx-beim.html
Regards Ingo
Afternoon Ian
Yes I believe they will be one offs for the game so I don't intend to add them in
You mil tac added in
Many thanks
