0 Members and 12 Guests are viewing this topic.
Evening Ingo,
3D0FD1,D-EEFX,26-0039,Mooney M20L PFM
I believe 072097  R72097 will be EC45 09-72097 miscoding its serial as its hex code instead of its allocated AE1F70.  It is based at Hohnfels AAF in Germany
Many thanks
Evening Terry, thanks again
Good morning Alan, Wednesdays unknowns:
3D0CA5  DEDAR (2x) http://www.airport-data.com/aircraft/photo/001228488L.html
3D197A  FHPAR F-HPAR: last one: http://tagazous.free.fr/affichage2.php?img=45454 Hex obviously false as from Germany
MILs:
   3E9D45  GAF177                                                         2017/02/15 07:45:42
   3E9D45  GAF177                                                         2017/02/15 09:36:23
* 3EBC85        2017/02/15 13:50:17
* 3EBC85        2017/02/15 15:00:54
* 3F44A3  DRAGON                                                         2017/02/15 08:50:07
* 3F6AC0  HG01A                                                          2017/02/15 11:15:37
* 3F6F43  BOMBER                                                         2017/02/15 14:11:47
* 3F8354  GAF111                                                         2017/02/15 08:38:52
3FF46E  DMTWT https://forum.luftfahrtclubbraunschweig.de/viewtopic.php?t=4848 and http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-MTWT
Regards Ingo
Morning Ingo,
3D0CA5,D-EDAR,15071060,Cessna 150J
3D197A,F-HPAR,125,Xtremeair XA-42 Sbach 342,Green Bird Aérobatic Team (Miscode allocated 39BC11) using the code of its old ID D-EHXA
3FF46E,D-MTWT,001,Air-Light Wild Thing,
Mil tac added
Many thanks
vonsmalhausen
had SP-ACC, ms 488042 yesterday, still showing as a Yak-12
should be a Cirrus SR-22T, cn 1012
Thanks Terry, I have hopefully put a block in place to stop those photos downloading.  You will need to remove them from your photo folder otherwise you will have them showing next time you pick it up
Many thanks vonsmallhausen, I have also updated my d/b provider as well.
488042,SP-ACC,1012,Cirrus SR22T
Afternoon Alan,
Some of these require recycling and some are not in the d/b :
ENT1573 : EPKT-GCFV
ENT1574 : GCFV-EPKT
EZY95MP : LEAL-EGGD
EZY37UQ : LEAL-EGPF
TCX58MQ : LEAL-EGCC
SAS97A : LEAL-ESSA
X
#9055
* 1F333A        2017/02/16 12:10:07
* 1F333A  5112005S                                                       2017/02/16 15:04:46
According to a Russian site this is RA-78650, Ил-76МД-90А №01-02 (should be 001 02), ICAO: 1F333A, however a shot I have seen recently shows it now in all over Mil grey c/s with no RA- or RF- prefix. It is also refered to as an IL-476, basically a totally upgraded IL-76 of which there are approx. 39 on order. 78650 to 78654 are already flying, so one assumes 1F333A thru 1F333E. Late last year I picked up 1F333D which is reported as being RF-78653. 78651/2/3 and 4 are RF- prefixed and from memory are in old basic Aeroflot c/s.
X
X
The article below shows 78650 in all its glory.
http://www.bing.com/videos/search?q=ilyushin+il-476&view=detail&mid=2A9789B55069E6F7A8AE2A9789B55069E6F7A8AE&FORM=VIRE
My database gives it as c/n P002 Unit number 01-02 and its the first flying prototype with the Ministry of Defence. but I presume it is now with the Air Force.  The database also gives them as RF-***** with hex codes as 155*** but I shall change to 1F**** and add them into the d/b.
1F333A,78650,P002,Ilyushin Il-476,Russia - Air Force
Alan,
Some more for you :
IBK5757 : GCXO-LEBL
IBK5756 : LEBL-GCXO
RYR86XZ : EGKK-LEAL
VLG7392 : LEAL-DAOO
VLG7393 : DAOO-LEAL
TRA38K : EHRD-LEAL
EWG926E : GCLP-LOWW
X
300325 I-EASX is flying around MOW pinging 300325 with c/s RA1675, I am assuming it is RA-01675 AW109SP 22334, however FR24 report it as a AW169. I do not know of any AW169's in Russia so looks like their Chopper spotting is as bad as mine!
X
