0 Members and 68 Guests are viewing this topic.
Afternoon Alan,
ISS3582 : LICJ-TFFF
IBK5333 : ENAL-LEAL
TRA9425 : EDDM-GCTS
Good morning Alan, Saturdays unknowns:
3D2E03  DEPRF (2x) no further information
3D4200  DEXGA no further information
MIL:
* 3F5266  GAF767                                                         2017/03/11 14:59:53
* 3F5266  GAF767                                                         2017/03/11 18:00:02
3FF13C  DMAUD still no luck with the details
3FF427  DMVGT still no luck with the details
3FF4E9  DMHCY still no luck with the details
3FF524  DMEYK still no luck with the details
3FF546  DMYPW Aerostyle Breezer http://www.flugzeugforum.de/threads/86425-Flugbetrieb-in-Osnabrueck-Atterheide-EDWO-2017/page7 (finally one found)
   471F70  WZZ170B  LHBP-EBCI                                             2017/03/11 18:44:08
   471F70  WZZ1441  EBCI-LHBP                                             2017/03/11 20:56:38
https://xfw-spotter.blogspot.de/2017/02/a321-231sl-wizz-air-d-ayag-ha-lxo-msn.html
Strange, that this one has slipped through...
Have a nice Sunday!
Regards Ingo
Quote from: Update
For some reason HA-LXO needed three populate cycles to get my MyLog.db updated.
diddyboy
Hi Alan
One unknown from the West Drayton area, so poss out of Northolt or Luton.
* 4D02CD  JFA20G                                                         2017/03/11 09:44:29
Neil
#9320
Morning Alan,
BER3KH : EDDT-LEAL
ELY395 : LLBG-LEMD
RAM964Y : GMMN-LEBL
AAF241 : LFPO-DAON
Out of LEIB is Hex A4D11F N4095H showing in the d/b as 'Various Cessna Airframes' however it is also showing I-FVAB as the flight ID.
EDIT : I-FVAB relates to a Cessna 525 (M2) c/n 525-0926.
Afternoon Ingo,
3D2E03,D-EPRF,40.234,Diamond DA 40 Star
3FF546,D-MYPW,,Aerostyle Breezer
Mil tac added and nothing on the others and HA-LXO as you found is already in the d/b
Many thanks
Nothing on it yet Neil.  The hex was used previously by ATP LX-WAD
Afternoon Terry
Yes noted the  Citywing issue, their aircraft have left for home but it doesn't affect the database.
Nothing I can do regarding F-RAJB there are no photos against it in the d/b.  Did you delete the photos from your folder the last time you picked it up
Hi Ian,
Thanks again re-cycled through.
A4D11F is a Cessna Test/Delivery registration and I am hopeful that  I-FVAB will soon be seen using its correct 300*** hex code soon.  If you wish I can change the registration field to VARIOUS and add In Use by more than one aircraft in the CO field if you think that would more accurately reflect the situation.  http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=4095h  The registration has been used by at least 3 Cessnas and a Mooney so far.  As it is a allocated as a test registration is used as and when required by the company with no need to update the FAA
Terry,
There is nothing in the database for photos for F-RAJB that includes the columns for photos that you mention so as before there is nothing that I can do.  If you have entries in your Navdata for the columns you mention, maybe you should delete them and change Autoupdate to N
I searched for Citywings the other day instead of Citywing, now removed from the 3 that had it included
support@airnavsystems may be able to help you Terry, I cant.
All I can suggest is that you delete the photos and the pttn entries and put N in the update field of the aircraft in your Navadata and it shouldn't do anything next time you see it.  I have attached the database entry for the aircraft and as you can see there is nothing in the photo fields so nothing I can do
chris
Hi Alan.
Ref 4D02CD I believe it is LX-JFA PC12/47E C/n 1633 Jetfly Aviation.
Chris
It is Chris,  I cant believe I didn't have it in the d/b already
4D02CD,LX-JFA,1633,Pilatus PC-12/47E,Jetfly Aviation
Many thanks
