0 Members and 66 Guests are viewing this topic.
Morning Ingo,
Mil tac added but nothing on your unknowns
Morning Terry, many thanks
jacobite
#9347
Gutten morgan Alan,
Just got 5 at the moment. They keep on coming.
EZY42XU      EGPH-EPKK
TCX532        EGPF-LTAI
EZE024P       EGNV-EGNJ
EZY69QD      EDDB-EGPF
KLM39C         EHAM-EGPE
Hello Alan, one unknown MIL from HD area today:
* 3E9A7B  GAF910                                                         2017/03/14 06:48:38
X
Picked up at 50ft with a max of 1250ft this US hex has me scratching my head! It decodes to N341SZ but nothing assigned on FAA list......but c/s looks more like a mil one...no doubt a miscode but picking it up at 50ft looks more like it was shipborne from the Forth and I did hear a chopper around that time!
* A3C2AD  BARON1                                                         2017/03/14 15:11:29
* A3C2AD  BARON1                                                         2017/03/14 15:52:21
X
X
Its is Puma ZJ954 miscoding.  It Is allocated 43C2AD
Good morning Alan, Tuesdays unknowns:
3C48E8  BER14P on its way to be prepared for the BER/EWG leasing deal : https://www.planespotters.net/airframe/Airbus/A319/3245/D-ABGH-Air-Berlin and http://www.airfleets.net/ficheapp/plane-a319-3245.htm
MILs:
* 3E9CBA  GAF910                                                         2017/03/14 13:30:29
* 3E9CBA  GAF910                                                         2017/03/14 15:21:59
* 3E9CBA        2017/03/14 17:19:14
* 3E9CBE        2017/03/14 15:36:11
* 3EB1A2  SW03T                                                          2017/03/14 13:10:18
478431  LNOPI http://www.nkom.no/npt/telefly/tillatelsesinformasjon.htm
Regards Ingo
Cjanderson37
Good Morning,
Mode S 780FE0 is coming up as Air China B-7859 but it should be B-7895 if you can correct please.
Thank you
Morning Ingo,
3C48E8,D-ABGH,3245,Airbus A319-112,Air Berlin/Eurowings ferried 14mar17 DUS-OSR for paint
478431,LN-OPI,,Aerospatiale AS350 B3 Ecureuil,Nor Aviation
Mil tac added
Morning CJ, amended thanks
Morning Terry,
Regarding  29C8E8 I intend to keep this miscode in the database as it is as it is being used by more than one US Military aircraft
A104DD decodes to N165GF the previous identity of N215TM so it looks like it has at least one box miscoded with its old hex so added as a miscode
Morning Alan,
Don't know how long these will continue to be relevant as it will soon be the dreaded March 26th !
EZY81EN : LELC-EGKK
RYR54TN : GCRR-LIPE
MON492L : EGBB-LEAL
EZY26UV : EGGW-LEAL
RAM1536 : GMTT-OEMA
THY5YN : LTBA-LEMG
