0 Members and 21 Guests are viewing this topic.
Quote from: AlanThe route will only show if its in the database.
That's why we spend hours and hours with investigation to get them in.
Many of my today posted routes were daily flights which will be done today afternoon and evening. I'll ckeck my log today morning to see how many have populated. Maybe there wasn't a problem with route autopopulate at all. But there was definitely one with aircraft populate.
Meanwhile you can add EWG7UJ EW7032 EDDH EDDK
Populate in MyLog seems now working as it should again.
Many Thanks!
WZZ571 is now W62310 EDDV LHBP
That one is in Ingo added a short time ago.  You will have had GWI9GC on your screen hopefully having populated as ESSA-EDDK which will not be showing a route on RB24 as I added it in on departure from Stockholm.
I have no idea with aircraft populate as I update my d/b each day and have not noted anything with them today as I have been busy with route info
Just noted WZZ571 on departure from Hannover
GWI9GC has populated, so route auto populate seems working as it should.
Download update is done with db of last Friday each month in the night to Saturday.
QuoteJust noted WZZ571 on departure from Hannover
Watched it too, that's why I noticed the false route info.
Yes it was using the previous info for that ID from November.
Just been adding some aircraft to the database and they populated right away with no delays
Any of them in my range?
Afternoon Alan,
CTN9500 : LDZA-LEMG
CTN9501 : LEMG-LDDU
Note the flight does not return to from whence it came !
No idea didn't really look to see where they were, takes time ;-)).  One was D-ITRA so it may well have been
MJet as per Austrian Register
Michel
Alan,
CFE8453 EGLC-EHAM
CFG8TV EDDH-LEJR
TFL6YC GCLP-EHGG
Michel
