squawk numbers
Started by EK01, January 28, 2017, 11:30:55 AM
Do you also have the problem of aircraft showing speeds of 0 knots ?
#16
As far as I know everyone using V6.00.000 and V6.01.000 has the 0knots problem.
The problem only occurs if used with SDR stick. It isn't present if RB1 (Classic Box) or RB Comstation is used.
Cheers Ingo.
That will explain things.
I note in V6 that the GS shows 0 but the IAS is detailed.  In V5 the GS shows but the IAS is blank
#19
I'd like to define Alans statement more precisely:
V6.00.000 & V6.01.000:
While operating with SDR Stick (e.g. mirco RB):
IAS is detailed, GS shows a valid value for about 1 sec every few seceonds. In the time between 0kt is shown.
While operating with AN RB Comstation:
IAS is blanc, GS shows stable values.
While operating with RB1 (Classic Radarbox Hardware):
V5.00.072:
IAS is blanc. GS shows stable values.
I should add that I was using a micro Radarbox stick using V6 comparing to a Radarbox on V5
