Author Topic: squawk numbers  (Read 19540 times)
squawk numbers
« on: January 28, 2017, 11:30:55 AM »
Hi guys,
Just notice that the aircraft on 'My Flights' are all showing unusual 5 digit squawk numbers instead of the normal 4 digit codes for example 21812/21346. Any one else have this and has there been a change of coding ?
Re: squawk numbers
« Reply #1 on: January 28, 2017, 11:37:24 AM »
Hi Ian
I don't know if it will help.  There is an update to V6 on the support page http://www.airnavsystems.com/download/ANRB/ANRB60001Setup.exe
Re: squawk numbers
« Reply #2 on: January 28, 2017, 11:41:41 AM »
Alan,
Running it now. It appears to be fairly lengthy so will see what happens.
Re: squawk numbers
« Reply #3 on: January 28, 2017, 11:50:28 AM »
Alan,
Scrub that. Just noticed Ingo´s comments on the 'password not saved' thread. How do I get back to version 5 which appears to be bug free ?
Re: squawk numbers
« Reply #4 on: January 28, 2017, 11:54:27 AM »
V5 doesn't work with the stick only the box
Re: squawk numbers
« Reply #5 on: January 28, 2017, 12:29:32 PM »
Hi Ian,
Try to go back to V5.00.072 by downloading and installing http://www.airnavsystems.com/download/ANRB/ANRBUpgradeto50072.exe
Or try to go back to V6.00.000 by d & I http://www.airnavsystems.com/download/ANRB/ANRBUpgradeto600.exe
V6.01.000 to V6.00.000 is working. I don't no if downgrading to V5.00.072 is working either.
If not a full new install would be necessary.
As Alan said, V5 is only working with RB1 (classic hardware). For Comstation or SDR sticks V6.xx.xxx is required.
« Last Edit: January 28, 2017, 12:32:24 PM by neroon79 »
Judwin45
Re: squawk numbers
« Reply #6 on: January 28, 2017, 12:41:26 PM »
Just installed V6.01.
Tried to start software but get stuck on the 'connect box'
Keith
Keith
5 miles south of EGDY
Re: squawk numbers
« Reply #7 on: January 28, 2017, 02:39:27 PM »
Cheers guys.
I'll just stick with version 6 for the moment which is giving the 5 digit squawk numbers except fro a Vueling flight which has the normal 4 digit code. Very strange.
Alan, time you were over here to fix this and get me off the dongle and back on to the box !
Re: squawk numbers
« Reply #8 on: January 28, 2017, 04:28:14 PM »
April 19th before I sail Ian, you are going to have to put up with the odd squawks for a while yet.  If its getting to you untick squawks in the columns list.
I have no idea why it should start that all of a sudden when nothing has changed with your set up.
Re: squawk numbers
« Reply #9 on: January 28, 2017, 04:55:07 PM »
Alan,
Now have some flights showing with a 3 digit squawk number. If I did untick squawks in the column list would I still be able to receive squawk alerts that I have set up ?
Re: squawk numbers
« Reply #10 on: January 28, 2017, 04:56:56 PM »
I-DUNO!!
Re: squawk numbers
« Reply #11 on: January 28, 2017, 05:01:52 PM »
Alan,
I'll give it a go and see what happens.
Re: squawk numbers
« Reply #12 on: January 28, 2017, 06:17:02 PM »
It shouldn't have any effect on your alerts Ian.  All you are doing is stopping them showing in the column
Judwin45
Re: squawk numbers
« Reply #13 on: January 29, 2017, 07:42:05 PM »
Hi.
I have gone back to version 6.0
Keith
astrathree
Re: squawk numbers
« Reply #14 on: January 31, 2017, 12:03:10 PM »
Hi I got the same problem with micro and reported it to Airnav
They are looking into it
