unable to connect
Started by vonsmalhausen, December 31, 2025, 09:38:34 AM
Betahal
Same here at BCN, Spain. "... Due to security reasons after 3 "unsucesfully" attempts to register...", etc. Here's hoping that they can fix that backserver issue soon!
jwyman
Yes, I am experiencing the same thing for quite some time....
They are working on an issue with the server which is causing an issue with the station pages,  The main screen is working correctly however and your feed will still be working ok, just the staion pages are offline.  It should hopefully be fixed later today as I was told earlier this afternoon it should be fixed in around 12 hours
I have no idea if this is causing the issue some V6 users are experiencing as it doesnt appear to affect all V6 users
vonsmalhausen
installed V5 to check if it would be V6 only ; no, the result was the same, still no connection
See previous message, there has been an issue on the server which is still being worked on.  The developers have the RB station pages back online but still to fix all outstanding issues
Glimmstengel
Same problem here... Still not working....
#21
Glimmstengel  I note you have changed your post.  Can I presume that since my post you have checked and found your xranges are indeed online
Betahal
Still unable to connect here at EXTSHA194882
Yes, I have the same issue since 07:00 01/01/26 running on a Raspberry Pi setup. Could it be a expired certificate/DNS problem on the AirNav servers?
Glimmstengel
Quote from: Runway 31 on January 02, 2026, 03:30:43 PM
I did not edit my post.... I use V6 and updated my RB today, then closed it and cannot reopen since... It doesn't connect
Sorry Glimsteggel I could have sworn you also said you have 2 xranges that were not showing.  Can whoever that typed that answer please
Seb
Its not that as plenty of box feeders are still online and feeding as can be seen here https://www.airnavradar.com/stations/airnav-pro-3d
eagle11
Alan,
I think those are users who stream 24/7; if you don't do that and try to reconnect, it doesn't work, as it did for me (see PGANRB113061).
Frans
Possibly that Frans but I know there are plenty like myself who only have it on during the day and I am not having any issue, you can also see this if you look at individual station where you can see them off at night and back on during the day.
They will be working away to get everyone on line
jwyman
