Part 2 - RELEASED - AirNav RadarBox 2009 - 3.0 Beta
Started by AirNav Development, June 28, 2009, 11:51:54 AM
abrad41
I had a play with vista, but I am now using xp again. totaly agree with you Allocator. Sent you a pm mate
Andy
neroon79
Don't know whether it's already reported or not. But I noticed, that the "StartPosition" and "EndPosition" information in the "Flights for selected Aircraft" section of MyLog is "useless" since I changed to the v3.0 Beta version.
The following error occurs: Only the Latitude position seems to be correct. The Longitude position is filled with the Data of the latitude position.
I hope the Bug with the "growing" aircraft trail without an AC symbol (Plane or square) on the top of it is also a known problem. ;-)
A Buglist at the beginning of this threat might be a good idea, because it may prevent the double-posting of already know problems.
11.75nm ESE of EDDV
HW:
Cable: 25m of ECOFLEX 15+
NB: Asus P53E 24/7 op.
PC: 28"4K + 24" Monitor
AirSpy mini @RPi3
Quote from: neroon79 on June 30, 2009, 08:03:43 AMDon't know whether it's already reported or not. But I noticed, that the "StartPosition" and "EndPosition" information in the "Flights for selected Aircraft" section of MyLog is "useless" since I changed to the v3.0 Beta version.
For Airnav.   This bug seems to have been introduced sometime between 14th and 17th June - so maybe at the end of the closed beta period.
malc41
Vista will install were ever you want it to as long as you don't let it do it itself. When you are asked during install select for example d:\airnav_2009_beta.
This works absolutely fine here
15 Miles East of EGNJ
EMA
In the Beta exe I tested last week that problem is now fixed and should be available soon.
Tallyho
Menu freezes - during closed Beta I discovered with the team that using a remote desktop software to access your ANRB will cause the menu freeze problems. The development team are aware of this and hopefully sorting out.
I can repeat this error using LogMeIn and VNC remote access software but i have not tried Teamviewer which I know a lot of you use.
Keith
neroon79
While playing with the map color, I got these nice screen shots:
Well, from my point of view, the Sea topography of the whole northern hemisphere seems to be scrambled like an unfinished puzzle. Southern hemisphere seems to be correct.
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
swadeep
Hi. Will the patch 1 make this work with VISTA 64 bit?? Please let me know AIRNAV. Thanks
waddington1
Many thanks for this info, it has been driving me crazy.  I use logMeIn, so that might be the reason.
Again many thanks for the information.
Stu
Quote from: Tallyho on June 30, 2009, 09:21:41 AM
Keith
swadeep,
The software runs fine with Vista64bit. If you mean the drivers are not being allowed to be installed on it then there are ways round this.
We are working with Microsoft to get the drivers certified.
Canonjohns40D
HI I have used Teamviewer since V3 upgrade and I can't recall any problems. Was it a particular part of the menu that froze as I'm happy to check it out on teamviwer for future reference.
Tallyho
The pull downs freeze in both the remote acces screen and on the live PC.
I associated it with the application being minimised as well. Worth a try maybe using TeamViewer fixes the problem. Would be nice to know.
waddington1
Quote from: Canonjohns40D on June 30, 2009, 12:26:54 PM
Hi John
Its the file,filters,tools,maps,help, etc, they just freeze, and the only way to get them to work is restart Airnav, then after a short while they stop working.
billmurphy
Hi all
I have downloaded the beta (3) version but when i click on the (new) desktop icon to run the program the Microsoft warning kicks in saying that RB has detected problems and needs to close, with the usual option for sending the report.  When i downloaded the upgrade to version 3 and then try and run it a window pops up and says that the RB.DLL is missing and cannot start but to try re-installing the software may help. I am using Xp service pack 3 and the version 2 runs fine and always has done.  Any suggestions?????
Thanks BILLY
