Part 2 - RELEASED - AirNav RadarBox 2009 - 3.0 Beta
Started by AirNav Development, June 28, 2009, 11:51:54 AM
pjp
Is possible, somewhere, read reported bugs ? Unfortunately I today see, that alerts don't work and this discuss is so long too check, if somebody report this problem. In v2 with some definition of alerts absolutely no problem ... :-(
Pavel
Hi PJP and welcome - alerts are being fixed.
dudbaker
I have just down loaded the latest version.  Got this message.
This application failed to start because rb.dll was not found.  Re-install the application may fix this problem
Dudley
Dudley Baker
Stansted
G8THH
Valiant, Victor, Shackelton, Canberra, VC10, Tornado Typhoon 737 747 A320 A300 Engineer.
malc41
Dudley is it the beta version you have downloaded?
If so check it has not installed itself as a seperate folder within your anrb folder, if so just copy the files into the origional folder overwriting the v2.1
15 Miles East of EGNJ
Jollygreen
Quote from: dudbaker on July 09, 2009, 06:22:26 PM
Dudley
I have just tried to download the patch and have got exactly the same message and as far as I can see anrb.exe has not been added to any other folder. AirNav Systems, help is required.
MTIA
Nigel
dudbaker
Dudley Baker
Stansted
G8THH
I assume you are talking about the patch version that development is talking about if so please use the closed beta testing forum.
Otherwise ensure you have downloaded the exe file to RB folder.
This is a well know V3.0 Beta problem. Wait a few more days to get the corrected version.
dudbaker
Airnav
How do you get access to the closed beta test forum.
Dudley
Dudley Baker
Stansted
G8THH
EGNXR
Quote from: Jollygreen on July 09, 2009, 08:18:07 PM
Dudley
MTIA
Nigel
Hello Jollygreen/Dudbaker
Does the patch show as ANRB.EX_
If it does you have to delete the underscore at the end and replace it with an E
so it looks like ANRB.EXE then it will work:-)
Copy your old ANRB.exe to a safe file first then cut and paste the new one in
HTH John
Based in Derby 5Nm NW of EGNX
Something to look forward to - better satelite image downloads:
Jollygreen
I have already downloaded the original 3.0 Beta version. I got an E:mail re the patch and that is what I cannot get to work. So do I have to wait a few days for this to be corrected before the patch works and I can check if the points I raised have been corrected?
Nigel
Jollygreen, when you downloaded the anrb.exe, what did you do with it?  You have to move it into the Radarbox 2009 folder and replace the one that's already there.
This discussion really should be on the closed beta forum.
dudbaker
At the risk of being told off for being in the wrong forum, I now have it working.  I moved the patch from Downloads to Airnav.  I now feel as if I am in the same club as everyone else.
Dudley
Dudley Baker
Stansted
G8THH
dudbaker
Tarbat
How do you get access to the closed beta forum.  It is no good telling us we should be their without telling us how to get their.
Dudley
Dudley Baker
Stansted
G8THH
