Started by orkney, May 31, 2014, 11:20:28 AM
Blueboy
Hi Andrew, I picked up HEX 201019 earlier which the database decodes as Hawker 400XP V5-WAW - But the flight ID was showing V5RON, which is a Learjet 45.
J.D
flygfantast
Andrew
The estonian 51109F was active again today and showing c/s ESVPM ( and it wasn't an SF340 ;-) )
ES-VPM, Piper PA-28-180 Cherokee Archer, c/n 28-7505177, Prop Air
Niklas
Cable: Ecoflex-10 (10m+1m)
orkney
Hello J.D and Niklas
J.D, That is 201019 changed to V5-RON which appears to be a learjet 75 version.  Niklas, ES-VPM is in now. It wasn't a Saab but at least we found out what is was.
Many thanks Again
Andrew
Evening Andrew,
OVA712 : LEVC-LEGR
WZZ792 : LEAL-LHBP not EPGD-LMML as given in d/b.
orkney
Hello Ian
That is that one added and the other one changed.
Thanks once again
Andrew
Michel
Andrew,
Unknown:
896199 (should be Emirates A380 A6-EEZ)
Michel.
orkney
Hello Michel
That one is now added.
Andrew
Kenny
Found this one but couldn't find the cn
750308  9M-MDI  DA42  DIAMOND 42NG MSN   op: MALAYSIAN DIE-CASTING INDUSTRIES SDN BHD
Kenny
ANRB 3km north of VTBD
orkney
Hello Kenny
That is that one added now.
Thank you
Andrew
Michel
Andrew,
TRA1583 EHAM-HEGN
Michel.
orkney
Hello Again Michel
That one is now done.
Andrew
Michel
Andrew,
GIA88 WIII-EHAM-EGKK iso WIII-EHAM
GIA89 EGKK-EHAM-WIII iso EHAM-WIII
Michel.
X
06A25F   QA75 A139 Qatar Air Force
06A260  QA76 A139  Qatar Air Force
X
Cheers X, I haven't been able to find the c/n details yet so added in without at this time.
