Started by orkney, May 31, 2014, 11:20:28 AM
Kenny
Two Jet Asia hex mixed up
HS-JAF B762 cn 24325   hex should be 882826
HS-JAK B762 cn 24007   hex should be 88282B
Kenny
ANRB 3km north of VTBD
Bob SEN
1/2 a mile South of EGMC/SEN
Thanks Kenny, I had them that way but was advised they were wrong following an eyeball, now corrected.
CYYZGUY
Hi Alan, can you check the routing on this..it is not populating..
ENY3412
http://uk.flightaware.com/live/flight/ENY3412
regards,
Jason
40" LED Monitor
40" LED Monitor
superspotter
Good morning from Lagos once again:
Hexcode C08863 is 5N-JEE Arik Air's new CRJ1000, still using the Canadian hex. It was supposed to have been delivered around a month ago but this is the first time I have seen it. It has just arrived as Arik 621.
regards clive.
Morning Clive, was looking at your returns earlier.
Thanks for that.  5N-JEE may well use its correct hex of 064168 on its other box.
superspotter
Hello again from Lagos;
Another one having changed it's hex?? Hexcode A86C1E is 5N-BIW Ce208Floats. Now I know I have given you this one ages ago, I first saw this in 2008, has it changed it's hex?
regards clive.
Hi Clive,
Yes it used 584000 previously.  BTW A86C1E decodes to N6416B and the only previous holder of the registration was a Cessna T210L.  The Caravans Previous registration was N1316N which decodes to A0821F, god knows how they get those hex codes!!
I am off on my travels back to Spain and will be offline until Sunday night/Monday morning.  Orkney Andrew will take care of your every need meantime.
Michel
Alan/Andrew;
TRA1233 EHAM-LGSA
TRA921 EHAM-LTAI iso EHEH-LTAI
New Easyjet on delivery; 406B91  EZY9001
Michel.
orkney
Hello Michel
That is all three added.
Many thanks
Andrew.
flygfantast
Alan/Andrew
N177LP is miscoding it's old hex of 4A812A (SE-GME)
Not populating: 51109F (Estonia)  (I wonder if it could be a new SF34 in the Estonian register, I believe it started from ESSL [home of Saab])
Niklas
Cable: Ecoflex-10 (10m+1m)
orkney
Hello Niklas
I can't find anything for you possible 340 yet but the miscode is added.
Thank you
Andrew
