Started by orkney, May 31, 2014, 11:20:28 AM
X
Hex 510087 was confirmed as IL76 EW-78836 as it departed Doha/Hamad today
X
Cheers X, got the email.  Unable to connect via the updater software this time,  Will add it in when able.
X
700026 is YA-AJH Canadair CL-600-2B19 Regional Jet CRJ-200LR c/n 7431 RECODED 11/4/14 and departed sandpit that day on delivery
X
Hi Alan
Not populating: 43C47F i/d ZR353. Possibly an AW101
Cheers X, both now added to d/b
Hi Rod,
Thanks, c/n 50258 eventually for the Italian Air Force where it is designated as an HH-101A
flygfantast
Not populating: 391D9C c/s FJSFE
4AAE69 SE-KSI, Saab 340B, c/n 340B-223, Saab AB
Niklas
Cable: Ecoflex-10 (10m+1m)
Thanks again Niklas, nothing on your French Microlight.
Xon
010191 1194/SU-BRV C295 / Egyptian Air Force
#1029
Thanks again Xon its is c/n S.095 which I had as using 010178 and from multiple postings on mode-S.  010191 is given as 1188 SU-BRW c/n S.103 which may not be delivered yet and appears to use CASA1188 as its mode S callsign.
Was your tie up from an eyeball?
flygfantast
Did you enter 4AAE69 into the d/b? It's still not populating. :(
Niklas
Hi Niklas,
I noted this morning that I had entered its hex code incorrectly and made the required changed at 0801 so should populate no problems.  If you look at d/b explorer and search by AR you will find it..   Looking at the server I see that 2 photographs are attached to it so someone has picked it up today.  http://www.airliners.net/photo/SAAB/Saab-340B/1927309/L/ and http://www.airliners.net/photo/SAAB/Saab-340B/1972614/L although they are from an earlier use of the registration.
flygfantast
Thanks Alan, populated after download and "fix" of new d/b :)
Niklas
X
#1034
This is a strange UK one! Climbed slowly over 4 hours to 34000...High Alititude weather ballon? Do not know if HAPS may mean something like 'High Altitude Performance System'. There is a large Blimp shaped Balloon out in the desert just past DWC.
* 406B52  HAPS                                                           2014/09/11 06:54:55
* 406B52        2014/09/11 08:31:14
* 406B52        2014/09/11 09:43:30
* 406B52  HAPS                                                           2014/09/11 10:18:08
X
