Started by orkney, May 31, 2014, 11:20:28 AM
superspotter
Well, you learn something new everyday! I tend to play around with the Db every few months and I have never seen that before, that tab always came up with some message I cannot remember...
CYYZGUY
Hi Alan
Mode S 29CC11
Flight ID N730LM
No other info populating.
regards,
Jason
40" LED Monitor
40" LED Monitor
Evening Alan,
IBE31ZR : LDDU-LEMD
VLG8179 : LEIB-LFPO not LFPG-LEMD as given in d/b.
LAV2083 : LIPE-LEIB
JAF8CK : full routing is LEAL-LEMG-EBLG. It does not terminate at LEMG.
Thanks Jason,
N730LM is miscoding, it should be using A9CC11.
CYYZGUY
#650
Hi Alan
Another unknown
Only thing that is populating is Mode -S
A89584
And another..
Mode S A65EDA
Flight ID N1WP
No other info populating...
regards,
40" LED Monitor
40" LED Monitor
Michel
Alan,
TFL259 EHAM-LGKO
TRA69L EHAM-LGIR
CAI708 EHAM-LTFE iso EHAM-LTBJ
Michel.
Morning Jason,
A89584 decodes to N652PY which is not assigned and doesn't appear to have been assigned previously so looks like a miscode but I have no info on what is broadcasting it.
A65EDA decodes to N5098L which is not assigned and the only previous user of the registration was a Cessna 152 which was written off.  The FAA shows it a allocated to Beech as a test registration.
The current N1WP is a B350 c/n FL-898 which is allocated A00204 no where near that picked up.  As it is a Beech there is a likelihood that it is this frame broadcasting the hex but I don't have any confirmation.
Chris11
Miscode
ZS-HMF Mode S is showing as A4443F (Should be    0093CA) A119 Augusta SPA AW119 MkII S A Red Cross Mercy Service c/n=14762
Judwin45
Hi Alan
Just departed Westland, 601860, EH101, this cross refers to B737 EZ-A009, so I guess a mis- allocation??
Keith
5 miles south of EGDY
X
#656
We think we have a new Ukrainian regged IL76 in sandpit hex 5082FE, possibly UR-CMC (ex ER-IAL) which is unknown, have you anything?
X
Hi Chris,
A4443F decodes to N374SH which was its previous ID.  The miscode has been added to the d/b.
Thanks again.
Thanks Keith, hope they get it sorted soon.
X
I have everything on it apart from the hex.  5082FE was first picked up 30/9/2013 around the time UR-CMC was first noted but maybe a coincidence as nothing confirmed that I can find.
