Started by orkney, November 12, 2014, 11:19:39 AM
Michel
Alan,
EXS25A LHBP-EGCC
Michel.
Morning Alan, the unknowns from Monday :
For sad reasons D--AIPX has to be removed from the database.
738E04 nothing more
780ABA nothing more
A8C70E decodes N665CR which is not reserved or assigned by FAA
AAAC4E decodes N787UE which is not reserved or assigned by FAA
MILs
* 3E9379  GAF214                                                         2015/03/23 09:58:10
* 3EA664  GAF120                                                         2015/03/23 09:13:35
* 3F4520  BADGR01                                                        2015/03/23 05:53:19
* 3F67CF  GAF775                                                         2015/03/23 12:19:41
* 3F6828  TA45                                                           2015/03/23 11:28:51
* 3F6828  GAF626                                                         2015/03/23 12:41:34
* 3F6828  GAF626                                                         2015/03/23 15:38:33
Regards Ingo
Afternoon Ingo, got in from walking the dogs to find out the very sad news.  My deepest sympathy to the relatives and friend of all on board and to all at Germanwings.
Thanks again, mil tac added and nothing further on your unknowns
falcon_nl
New ones:
485169, PH-HCD, G2CA, Guimbal Cabri G2, 1034
43E98B, M-SAID, GL5T, Bombardier BD700 Global 5000, 9486
Thanks again falcon_n, appreciatedl.  M-SAID is in the database but PH-HCD is new.
Afternoon Alan,
EVE1307 : LEZL-LEMH (The return is EVE1308)
EVE1464 : GCXO-LEAL
EVE1465 : LEAL-GCTS (This is the return flight of the above and is confirmed as going to GCTS not GCXO).
Afternoon Ian
#2048
Hi Alan, Unknowns from Tuesday :
3D15C7 nothing more
400FEA was G-RJXO E145  nothing about a new one
45AD83 nothing more
4784ED nothing more
* 4BAA6E  THY6900 TC-JSN A321 on delivery. Therefore already added to the db?
60183F nothing more
A300B2 decodes N293AU which is not reserved or assigned by FAA
MILs :
* 3EA47A  CATO7                                                          2015/03/24 15:08:02
* 3F40D0  HG01A                                                          2015/03/24 18:02:17
* 3F4890        2015/03/24 14:53:00
* 3F60B7  STRIKE1                                                        2015/03/24 15:10:14
* 3F6245  JUSTIS                                                         2015/03/24 14:38:08
* 3F7D9A  NITRO3                                                         2015/03/24 10:03:05
* 3F7D9A  STRIKE3                                                        2015/03/24 15:05:36
Regards Ingo
jacobite
Hi Alan, have you any info on the following, 43C738.
I can't find any thing.
Afternoon Ingo,
3D15C7 D-EGMP Cirrus SR22 GTS c/n unknown to me
4BAA6E TC-JSN missed it but it is now in the d/b
Nothing on the others and the mil tac added
Many thanks
#2051
Hi Ian,
Nothing yet on 43C738.  It was using QRA24002 as its flight ID so expect its a new EUFI
aLAN
Ian,
EUFI ZK310 departed Lossiemouth on a QRA around 1150 callsign X3P17, maybe?? but nothing confirmed.
Hi Alan
43C7B2 is cruising at 25000ft somewhere near me and not populating.
Hi Rod,
Nothing on it yet, suggest its a new EUFI out of Warton
