Started by orkney, November 12, 2014, 11:19:39 AM
Hi Alan, Unknowns from Wednesday :
4BBC85 nothing more
4D00F2 nothing more
5CA9ED no country allocation
AB6C0C decodes N835MM which isn't assigned or reserved by FAA
MILs :
* 3F7B08        2015/03/25 09:36:18
* 3F7B08  BU03T                                                          2015/03/25 10:18:45
* 3F84B2  DARK                                                           2015/03/25 17:34:21
* 3FA85E  GAF268                                                         2015/03/25 15:24:52
* 3FA85E  GAF268                                                         2015/03/25 16:51:32
Regards Ingo
Morning Ingo,
Mil tac added and nothing to add to your unknowns
Afternoon Alan,
AEA2644 : LEAL-LEBL
EXS53Q : EGPH-LEAL
VLG3148 : LEMG-LEPA
LAV5471 : LEBL-LEAL-LEXJ
EVE1314 : LEIB-LEMG not LEBB-LEAL as given in d/b.
EVE1602 : LEIB-GCLP not LEMH-GCLP as given in d/b.
Summer schedules starting ?
CYYZGUY
40" LED Monitor
40" LED Monitor
Cheers Ian, I saw the EXS flying south of Valencia and thought I could get it in the d/b before you picked it up, evidently not!!
falcon_nl
New one:
3FF3CD, D-MENP, C42, Comco Ikarus C42
Hawkeye
It would seem that your follow up to Rod's post 2053  re 43C7B2  suggesting it's an EFA, is correct as dtvmovements say the same.
43C7B1,  WTN29 has just been out and about in the same area and 'dtvmovements' confirmed that as Typhoon ZK600 on the 23rd
Syd
Thanks Syd, for info ZK600 will eventually go to Saudi Arabia, this new one will probably be the same.
Out of XFW on delivery to Avianca Brasil as ONE9581 is E490ED PR-OCH Airbus A320-214 c/n 6528
CYYZGUY
40" LED Monitor
40" LED Monitor
CYYZGUY
An unknown for me today
Mode-S C015AD
Only information populating.
regards,
Jason
40" LED Monitor
40" LED Monitor
Thanks Jason
C-15AD decodes to C-FIFK.  Nothing showing  on the Transport Canada Website.  I think it may be CL605 N138DM miscoding its old ID as it was only transferred to the US register 9/3 but I have no confirmation on that.  It should use A09940.
CYYZGUY
40" LED Monitor
40" LED Monitor
