Started by orkney, November 12, 2014, 11:19:39 AM
CYYZGUY
40" LED Monitor
40" LED Monitor
X
From basel area
* 3D1D93        2015/03/26 17:43:28
* 3E1211        2015/03/26 15:46:59
* 3F8330        2015/03/26 12:01:01
* 406CD2  EZY5454  LCPH-EGKK                                             2015/03/26 17:16:03
* 4B1EDF  HBLRZ                                                          2015/03/26 11:04:33
* 4D02F3  LXFDI                                                          2015/03/26 12:33:18
* A1BB03        2015/03/26 11:17:02
Back to sandpit tomorrow
X
Hi X
3D1D93,D-EJLJ,2617,Robin DR 400/140B Major
3E1211 decodes to D-HYAR but is D-HZAR R44 miscoding in d/b
3F8330 German mil tac code
406CD2 G-EZOF A319 c/n 6525 back to EZY from EZS in d/b
HB-LRZ not on Swiss online register.  My d/b shows it as cancelled last month as exported to ?
4D02F3 LX-FDI noted today for first time and is an unknown yet
A1BB03 N210RK H25B in d/b
Enjoy the flight, hope its not as early as your inbound to Basle
CYYZGUY
Morning Alan, in case you missed my reply #2071
40" LED Monitor
40" LED Monitor
falcon_nl
Found finaly something about D-EPRS
D-EPRS, 3D2E10, SR22, Cirrus Design SR-22 GTS
Morning Jason, I had but got it now, return flight added as well,  thanks again
CYYZGUY
40" LED Monitor
40" LED Monitor
Afternoon Alan, Unknowns from Thursday :
* 3E22F4  DIEKU https://www.flyvictor.com/aircraft-operators/starwings-luftfahrtges-gmbh/citation-cj2-d-ieku
* 4BA8DE  THY2EW   EHAM-LTFJ
* 7583A8  PAL5005
8007DB nothing more
 A21A97  N2346S
* A43326  N37TL
* E490ED  ONE9581
MILs :
* 3E84FE  GAF701                                                         2015/03/26 08:44:33
* 3E9951  GAF103   BIKF-EDDK                                             2015/03/26 08:18:36
* 3F6838  NITRO02                                                        2015/03/26 10:04:30
* 3F72FC  NITRO03                                                        2015/03/26 10:59:33
* 3F72FC  NITRO2                                                         2015/03/26 14:29:07
* 3F8D5D  NITRO1                                                         2015/03/26 10:03:26
* 3F8D5D  STRIKE2                                                        2015/03/26 14:31:16
* 3F9755  GAF640                                                         2015/03/26 08:57:24
* 3F9755  GAF640                                                         2015/03/26 11:37:39
* 3F9D3F        2015/03/26 17:25:41
* 3F9DDD  GAF775                                                         2015/03/26 10:30:34
* 3F9DDD  GAF775                                                         2015/03/26 12:48:03
* 3FAC61
Regards Ingo
CYYZGUY
40" LED Monitor
40" LED Monitor
Afternoon Alan,
LAV5153 : LIMC-LEZL
VLG4016 : LEAL-LFML
VLG4017 : LFMT-LEAL
I have the feeling that the 2 Vueling routes are one-off charters in connection with the plane crash in the Alps .
ian
Afternoon Ingo,
3E22F4 decodes to D-EIKY. D-IEKU is in the database correctly with hex 3E22F0.  It is either miscoding or it was a corrupt packet
4BA8DE  THY2EW  doesn't decode to presumably a corrupt packet.
7583A8  PAL5005 RP-C9919 A321 on delivery and in d/b
8007DB doesn't decode
A21A97,N2346S,172S9999,Cessna 172S Skyhawk SP,Southern Aircraft Consultancy Inc Trustee
A43326 decodes to N37TL but not current on FAA.  However the only previous N37TL I could find is a Denney Kitfox which is now HB_*** so probably it using its former hex and ID
E490ED NE9581 PR-OCH A320 on delivery and in the d/b
Mil tacs added to d/b
Have a great weekend
