Started by orkney, November 12, 2014, 11:19:39 AM
Thanks Ian, I presume that the return flight should also be from Marseille.
Alan,
It actually came into LEAL from LFMT which is given as Montpellier and returned to LFML (Marseilles) so not sure if it is an error. Too late to view the AENA board. Also do not know if the runway at Montpellier is able to take an Airbus.
Its is Ian, LFMT is used by Air France and easyJet among others.  I tried the AENA board but nothing there.
Out of Toulouse on delivery to Korean Air as KAL90D is 71C025 HL8025 Airbus A330-323E c/n 1611. Looking set for a UK airspace incursion en-route
CYYZGUY
40" LED Monitor
40" LED Monitor
Have a great Weekend too.
D-IEKU: entry caused by bad packets received.
THY2EW: was also caused by corrupted mode s packets.
Thanks! Ingo
CYYZGUY
#2094
AAL1065
No routing
https://flightaware.com/live/flight/AAL1065
Seems to go back and forth from Chicago to Boston
regards,
TSC1701
No Routing
https://flightaware.com/live/flight/TSC1701
regards,
JAson
40" LED Monitor
40" LED Monitor
flygfantast
3EA984 Tactical
4AC9B4 SE-RMT is SAAB AB newest aircraft :)
Niklas
Cable: Ecoflex-10 (10m+1m)
Morning Alan, the unknowns from Friday:
3C7D85 nothing more
* 406D8C  EZY9001 this Airbus on delivery: http://xfw-spotter.blogspot.de/2015/03/a320-214sl-easyjet-d-avvf-g-ezog-msn.html Maybe I've received it before you have entered it...
4CA8CB nothing more
500084  T7RSN nothing more
A12C31 decodes N175EN currently not Assigned/Reserved by FAA
AE0A7F US MIL no further info
MILs:
* 3EA4CA        2015/03/27 09:17:25
* 3EA984  GAF374                                                         2015/03/27 08:36:42
* 3EB483  NITRO3                                                         2015/03/27 09:25:30
Have a nice Day!
Morning Ingo,
3C7D85 decodes to D-AOLE unknown to me
406D8C  G-EZOG A320.  It was over Northern Germany heading into Dutch airspace when I added it in, would expect you had it before I added it in
4CA8CB unknown to me
500084 T7-RSN noted first time out of Guernsey on Thursday for Ankara is suspected to be ex TC-RSN F2TH but it landed in Southern UK yesterday so hopefully it will be ID'd soon
A12C31 no idea
AE0A7F tac code
Your German mil tacs added
Many thanks and have a good one
