Started by orkney, November 12, 2014, 11:19:39 AM
DLH5CF D-AIZP now EFHK-EDDF (LH853)
DLH4UP D-AIRS now EDDH-EDDF (LH007)
DLH4JA D-AIPM new EDDF- (LH...)
THY5DL TC-JHY now LTBA-
OH-LVK FIN5X new EFHK-
DLH3RM D-AISW now EDDF-
DLH8XC D-AISN now EDDF-
X
Two unknowns in sandpit area
* 896156        2015/03/28 22:26:01
* A99624        2015/03/28 22:22:05
X
DLH8UV D-AILE now EDDF-ESGG (LH812)
DLH8FM D-AIBI now EDDC-EDDF (LH209)
DLH5PL D-AIRC now EDDF-EDDH (LH006)
DLH9FF D-AIZZ new EDDF-
DLH6KV D-AIDD now EDDV-EDDM (LH2091)
GWI7F D-AKNL now EDDT-EGLL (4U8460)
GWI48W D-AIQL now EDDT- (not in departure timetable of EDDT)
GWI6903 D-AIPT now EDDH- (not in departure timetable of EDDH)
DLH1XV D-AILW now EDDW-EDDM (LH2109)
DLH2FL D-AIBC now ENGM-EDDM (LH2457) has to be ckecked as not 100% sure
DLH7JT D-AISR now EDDT-EDDF (LH177)
DLH8YX D-AISH now EDDH-EDDF (LH009)
DLH4LL D-AIBF now EDDF-EDDV (LH048) needs final checking
DLH9TT D-AIDF now EDDM-
Thanks Ingo,
Will work my way through those.  As well as DLH, GWI,THY,IBE, PGT,KKK have all changed, woopeee doo
Morning X
896156 shows as A6-AVD no further info.
A9624 decodes to N717AX nothing on FAA
I'll have a couple of Days off from Work around the easter Halidays (04-01 until 04-07). So I'm able to do the early shift in the current flight id investigation series...
0,1% of DLH done 99,9% left.. yippi-ka-yeah!
Many thanks Ingo, very much appreciated
Morning Alan,
VLG6570 : LIRF-LEZL
SAS4676 : LEAL-ENGM
There was also a VLG1236 but it would appear on checking with AENA that flight crew have entered an incorrect ID. It should be VLG1326 the route details of which we already have and are correct.
I have also been onto the Vueling website and discovered the attached which gives DAILY details of their schedules. I have checked and if you substitute the VY flight ID with VLG it gives the correct information.
Unfortunately, it would have to be checked on a daily basis presumably until a full week has been covered. It comes under Vueling Services and then Flights Today.
http://www.vueling.com/en/vueling-services/flight-information/flights-today
Thanks again Ian and many thanks for the link
Alan,
MON96FK : LEAL-EGGW
BEE6TR : EGHI-LEAL not EGPE-EGKK. The return to EGHI is also showing as BEE6TR. Not sure if it is meant to be or if the flight crew have just not changed the return details.
Hi Ian
The return should be BEE68Q so looks like its not been updated by the crew
I've posted my Saturdays unknowns in reply #2111. Although I bet that there isn't much to do for you it would be great if you have a look at them.
Thanks!
