Started by orkney, November 12, 2014, 11:19:39 AM
flygfantast
#2100
Not populating: 4CA139 c/s EIEWR. 2867 msg(s) recevied & ADSB. :)
From Skyliner:
EI-EWR, Airbus A330-202 c/n 330, Aer Lingus, delivery 28mar15 MNL-DUB ex 9M-XAD
Niklas
Cable: Ecoflex-10 (10m+1m)
Ingo,
I note from another source that AE0A7F used a flight ID of RCH337 which suggests it is not tactical.  I have therefore removed it from the d/b and is for now unknown
I have been advised by falcon_nl that mil modes gives AE0A7F as K35R 59-1509 so looks like it is a miscode as it should use AE047F)
#2104
Evening Alan,
Thought I´d get in early before you get swamped tomorrow with the start of the summer schedules :
WRC7738 : LEZL-UKLL
EZY14PD : LELC-EGKK
And just come over operating RYR92KU GCRR-LEBL is Transaero B737 EI-EUZ c/n  29355.
Evening Ian,
Thanks again.
Re the RYR, unless of course its EI-EKR with another miscode.
BTW Just added in 2 WOW ID'S inbound LEAL from BIKF this evening WOW515 and WOw517.  515 may show something else from what I noted on the network.
#2106
The summer schedules for the following are being loaded in this evening.
AUA, BAW, BEE, BER, BHP, CFE,EXS, EZY, NLY, RYR, SXD, SXS, and TRA for the next 6 weeks
Any others would be gratefully received
Alan,
Noted re the Ryanair/Transaero. It´s the first time I have logged that Transaero  over here so may or may not be a miscode. Confirmation welcome.
As far as the Wow Air´s are concerned, the arrivals board shows a WOW517 from Kevlavik at 21.05 and WOW515 arriving from Kevlavik at 21.30. Departures are WOW518 at 22.05 but nothing given for what is presumably WOW516 for today or tomorrow. It´s unusual to have 2 WOW Air flights in at virtually the same time therefore can only suggest that WOW515 is a positional flight for some reason.
Alan,
WOW517 arrived operated by A320-232 LZ-MDC c/n 4270.
WOW515 arrived operated by A320-232 TF-WOW c/n 2457.
Also, to keep you busy here is the DLH summer 2015 schedule. Well , you did ask !
http://dl-oim.de/download/LH_Timetable_en.pdf
Cheers Ian, unfortunately it only contains the commercial flight numbers not the flight ID's
Morning Alan,
Summer Shedules: here we go...
DLH2FM LIRF - EDDF isn't correct anymore D-ABEK LH207 DLH2FM EDDC - EDDF
GWI37M (4U7584) D-AIZQ EDDH - LEPA
Have a nice Sunday!
The unknowns from Saturaday:
303F1D nothing more
34454E nothing more
3FF3BA  DMKSA possibly a Klüver Bison Trike, but not 100% sure
4CA220 was EI-DFJ E170 until 2012 nothing about a new one
7C3F6C nothing more
803F68 nothing more
A72790 decodes N560GR cancelled from FAA Register in 2006
DLH7EL not correct anymore, now D-AILC (LH2105) EDDV-EDDM
DLH4EK not correct anymore, now D-ABED (LH351) EDDW-EDDF
DLH5MA not correct anymore, now D-ACNC (LH063) EDDG - EDDF
#2113
DLH6VR D-ABEH now EKBI-EDDF (LH843)
DLH3MA D-ACKI now EKCH-EDDM (LH2447)
DLH5LX D-AISR now EDDF-EDDT (LH...) wasn't able to find it in departure Timetable / arrival Timetable
RYR4RC EI-DAD new EYKA- (FR...)
DLH2TN D-AILP now EDDF-EDDV (LH046)
DLH6LA D-AIDD now EDDM-EDDV (LH2090)
DLH9TP D-AISF now EDDT-EDDF (LH173)
DLH3WU D-AISE now EDDH-EDDF (LH005)
THY3RF TC-JPS new EDDH-LTBA (TK1668)
DLH5RK D-AISH now EDDF-EDDH (LH002)
DLH2HP D-AIUB now ESSA-EDDF (LH809)
