0 Members and 17 Guests are viewing this topic.
Morning Terry, thanks again.  The N registration does it for me in differentiating
Afternoon Alan,
Not populating : 4912DA
Flight Id : CS-DVZ
BMS5574 : LEAL-EGGP
BMS5573 : EGGP-LEAL
Afternoon Ian
4912DA,CS-DVZ,550-0443,Cessna 550 Citation II,
paul tricker
I have been informed that the RAF's latest toy arrived at Mildenhall this morning, but was still using the hex from its old serial
AE07C5  ZZ666 RC135W Royal Air Force  (was 64-14830)
I assume it will get recoded at some point
Paul
Thanks Terry, my coding error
Good Afternoon/Evening Alan, Mondays unknowns:
39461C  FJWEC (2x) nothing new to report
3D67DE  DFLOW (2x) nothing more
MIL:  * 3EB292  GAF312                                                         2017/06/05 14:33:25
3F282E  DOBCW (2x) https://abpic.co.uk/pictures/view/1017113
3FCC78  DOOWE (3x) http://www.balloonworld-steinhagen.de/index.php?seite=fahrten
3FEFE3  DMDCK nothing more
4407EE  DEVOT hex matches to OE-DTM, which is not at austrocontrol. So maybe it's D-EVOT ex. OE-DTM still using old hex.
Regards Ingo
Tykes Aero Blog
Hi Alan, just a quick note for you that 9M-LRG is miscoded 75041E which is used by 9M-LRC.  It should be 750421 and was seen as such pinging back on April 27 so how/why it's ended up with the same code as 9M-LRC is a mystery.  Not really much you can do in the database except make a note of it and hopefully it will get fixed before it flies away.
Tykes Aero Blog
Hi Alan, new one for you :
7811D4
B-1482
B738
Boeing 737-8EH
40741
Chang An Airlines
CGN
2015-10-19
Evening Alan,
EXS676 : LEAM-EGNX
EXS675 : EGNX-LEAM
VLG23FP : LIRF-GCFV
CFG5ED : LEIB-EDDM
Hi Ingo
Mil tac added
3F282E,D-OBCW,1059,Ballonbau Worner NL-1000/STU
3FCC78,D-OOCW,1055,Ballonbau Worner NL-1000/STU
4407EE  DEVOT 3307EE decodes to OE-DTM.  I have 2 frames which used that registration. Beech F33A Bonanza CE-1439 which was cancelled in February but have no idea on its new ID.  Also a P28R which is now D-ENLB.  The BE33 is a possibility but no confirmation
Nothing on the others
Hi Tyke,
Many thanks.  I will leave 9M-LRG just now in the hope it is corrected for delivery
Tykes Aero Blog
Quote from: Tykes Aero Blog on June 06, 2017, 06:43:41 PM
7811D4
B-1482
B738
Boeing 737-8EH
40741
Chang An Airlines
CGN
2015-10-19
Note that has been posted elsewhere as Fuzhou and also Shandong !  It flew as CGN1482 which also happens to be the code for Chang An.
