0 Members and 17 Guests are viewing this topic.
Yes Tyke, saw the post thanks
CarlosAbreu
Today:
TAP9103   LPPS-LPPT
EDW284K   LSZH-LPMA
BMS8SC   LROP-LPPT
AZU8750   SBKP-LPPT
AZU8751   LPPT-SBKP
LLX5823   EDLP-GCFV
HFY001P   LPBJ-LGAV    (Ferry flight as HFM611 yesterday)
EDW285C   LPMA-LSZH
TAP803V   LIMC-LPPT
TAP1434   LPPT-GMMN
NLY1AH   LSZH-LPMA
RVP952   LPCS-LPBG   -LPVR
RVP953   LPBG-LPCS   -LPVR
RVP954   LPCS-LPBG-LPVR
U2916W   LFPG-LPPT
TAP1533   LPPT-GVNP
TAP1688   LPMA-LPPT
QTR3253   LROP-LPPT   (Ferry flight for sharklets install at TAP Maintenace)
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
yang
AA8582 is not N77709. It is B-77709.
Modes S   Hex   : AA8582
Registration   : B-77709
Aircraft Name   : Partenavia P-68C-TC
msn      : 467-47/TC
Airline:   : Sunrise Airlines
Country      : Taiwan
Many thanks Carlos.  I do not add in ferry flight or positioning flight ID's as these are valid for one flight and can be reused again on a different route
Hi yang
Please see http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=n77709  N77705 is current on the FAA list and is allocated hex code AA8582.  B-77709 is unfortunately using a miscode resulting on both aircraft using the same code, one correctly and one incorrectly in the case of the P68.  I presume that it should use something like 8991F9 as it shex.
As the G150 is more likely to be picked up and it is using its correct code and you are less likely to pick it up at your location that you manually update the record to show the P68 which you are likely to pick up.
yang
Alan,
got it.
many thanks.
Yang
Morning Terry, the EZY was restored yesterday and added in this morning ex HB-JXG, thanks again
Hello Alan, Tuesdays unknowns :
3DD74D  DHBUB D-HBUB - Aerospatiale 365N2 Dauphin 2 (6514) of Rotorflug GmbH, 06/2017. Source helionline.de
MILs:
* 3E89CA  GAF409                                                         2017/06/06 07:47:55
* 3E89CA  GAF409                                                         2017/06/06 10:46:28
* 3E99AE        2017/06/06 09:08:59
* 3F4511  PACK31                                                         2017/06/06 08:20:31
* 3F51B7  GAF038                                                         2017/06/06 09:45:22
3FF53A  DMFLC no further information
Regards Ingo
Afternoon Ingo,
All added in
Afternoon Terry, many thanks
AoD
BCS5132   EDDP - LHBP
BTI483   EVRA - LKPR
BTI484   LKPR - EVRA
CFG6LK   LGIR - EDDV
CSA434   LKPR - LMML
LLC3312   LPMA - EYVI
LLX5123   LCLK - EDDP
SQC7367   EHAM - OMSJ - WSSS
company update:
49D3B2   OK-BRO   T-Air
CarlosAbreu
#10858
By your instructions I'll not include detected ferry flights in my reports.
Today:
NAX1786 ENGM-LPPT
RYR9371 LPFR-EIDW
MON585U LPFR-EGCC
RZO250 KBOS-LPPD-LEBL (NV LPPD)
Please correct following flights posted yesterday the ND field was incorrect due to a typing error.
RVP952 LPCS-LPVR-LPBG (NV LPVR)
RVP953 LPBG-LPCS-LPVR (NV LPVR)
RVP954 LPCS-LPPVR-LPBG (NV LPVR)
Carlos
