0 Members and 17 Guests are viewing this topic.
#13875
Carlos
With two units having the same coverage from the one antenna this would point to an issue with the antenna and or its cables.
Its the same driver package for 32 and 64 bit and the software wont give a reduction in range so to me its a co-incidence.  http://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip
Also if there was an issue with the software it would be a reduction all round not just in one direction.  Range issues are normally always connected with the antenna, cables or connections.  As the reduction is in only one direction, look for an obstruction.
Thanks again Terry
Alrosa standardised on Alrosa Air Company as per their website
CarlosAbreu
I agree. Problem must be somewhere in antenna, cables or connections, I'll try to check today everything again in 1s floor and roof in weekend.
At this moment range is lower and not only in one direction, I'm not getting more than 76,21 NM in a 360ยบ radar ring.
Back to you soon.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
In that case Carlos it may be the box itself unless the other box was the same.
CarlosAbreu
Great news, problem solved !!!
In my second test to 1st floor cables and connections when I was checking a external conector I noticed that it was not strongly fixed like the others so I opened it and "bingo" !!! Due to poor cable condition I cut damage part and applied a new Ecoflex 10 connector.
Now everything is working fine and range is normal as you can see by screen shot in attach.
Thanks for all support !!!
Note: ANRB tested was similar to mine (1st black boxes from 2008)
Carlos
Glad you got it fixed Carlos
Evening Terry
As far as a am aware UR-NTA and NTC are WFU Stored
CarlosAbreu
09-02-2018 Updated file in attach.
Carlos
ffa1978
Nothing on that 2-**** hex yet ffa
Morning Alan,
RAM955V : LIMC-GMMN
RYR4JP : GCRR-LIME
IBK515 : LEMG-EFHK  Being operated by B737 -8 MAX EI-FYD. First Norwegian one noted over here.
Hello Alan, Fridays unknown:
5083D0  AUI1916 UR-PSZ and already added I guess.
Morning Ian, thanks, all recycled back in
