0 Members and 26 Guests are viewing this topic.
Morning Ingo
Nothing concrete on D-FFUN yet.  It came out of Tarbes so Looks like it is a new TBM
Morning Alan,
VLG3153 : LEPA-LEJR
VLG3154 : LEJR-LEPA
BEL3776 : LEAM-EBBR
BEL3775 : EBBR-LEAM
CFG3AH : EDDF-GCLP
VLG21GU : LEMG-LEBL
RYR4LH : LEMG-LEBL
RYR691 : EGPK-LEAL
RYR692 : LEAL-EGPK
RAM603 : LFML-GMMX
I suspect that most of these just require recycling. The RYR691 route was originally showing, I then performed my usual Monday d/b update including routes and when I put AN back on again, the RYR691 route was not showing.
Morning Ian
A couple of new ones.  RYR692 has been using an alpha numeric up till now, we will see if its a one off
#13909
Morning Terry,
Am keeping Sec as per companies website and Transport Canada
Also keeping the 2 Gama Beeches as Gama Aviation (UK).  They use the GMA flight ID same as the others in the fleet.  Please feel free to amend you d/b as you see fit.
Afternoon Alan,
Another couple for you :
RYR21SR : EIDW-LEAL
MAC224 : EDDK-GMMW
NOS363 : GCTS-LIPX   I suspect this is a one-off charter as it does not appear on the departures board.
Cheers Ian, thanks again
CarlosAbreu
Over cable operation finish but missing range, I only have sinal for arrival/departures from LPPT but in a very short range.
I've got a problem somewhere in a ecoflex 10 connector, yesterday I checked my 1st flor three"N" connectors  for 4 times and I can't found cable problems, it seems everything is ok but loss of signal still on.
Today I'm going to see some vĂ­deos in internet in order do look for correct cable assembly and identify the bad conection. A friend told me this is a typical problem of cable mass (?) !!!
Pleasea advise.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Hi Terry,
I had it in as Aviation Jolina S.E.C, but you didn't like it being correctly entered that so I changed it to what I found on the internet using Google.  I have changed it back to what is shown by Transport Canada
Encryption has nothing to do with it.  What you describe is for showing photos.
If you don't like the information I add to the database and want to append something different you must set up your system to ignore the database.  Have N inserted for Autoupdate on each record you want to keep different and when you update the database use the Do not update manually changed records option.
Also in preferences under Photo and Aircraft Auto-Populate untick Auto Update Manually Changed Records.
The aircraft you mention use a GMA flight ID which is the ICAO code for Gama Aviation (UK).   As all the British Registered aircraft are owned and operated by the same company using the same ICAO code and radio call sign from the same address at the Business Aviation Centre in Farnborough I have standardised all to Gama Aviation (UK) https://www.gamaaviation.com/locations/farnborough-hq/
I am keeping SP-Dom as Owner Victoria Dom/AMC Aviation as Operator as per the information provided by my database
Good morning Alan, Mondays unknonws:
3D5899  DFFUN (3x) very active, I saw it here in HD yesterday evening too. Still no details.
two MILs:
* 3E8250  GAF012                                                         2018/02/12 07:24:45
* 3E8250  GAF012                                                         2018/02/12 10:17:00
* 3E8250  GAF012                                                         2018/02/12 11:32:05
   3E8F05  GAF142                                                         2018/02/12 07:17:32
71040E  SVA9037 just in case: https://xfw-spotter.blogspot.de/2017/11/a320-214sl-saudi-arabian-airlines-d-hz.html
Regards Ingo
M
LOT12B   EETN   ESGG
ABW611   UNKL   EDDF
ABW453   UNKL   EHAM
CLU404   KORD   UUEE
SWT3848   EKCH   EFHK
SWT3849   EFHK   EKCH
TVF1708   LFPO   EFKT
TVF1706   LFPO   EFIV
AUA2631   LOWW   EFKT
AUA2632   EFKT   LOWW
KTK112   MMUN   UUDD
KTK111   UUDD   MMUN   via MDPC
TRA735   EHAM   EHAM   via EFKS
BEL1135   EBBR   EBBR   via EFKT
NTJ63H   ESUT   ESSA   via ESNV
Operators:
UR-CBF Aerovis Airlines
VQ-BRQ Globus/S7 Airlines
9H-MSL Skyfirst
CS-CBA Executive Jet Management Europe
T7-PRM ICS Aero SM/IBE Trade
D-CKNA Star Wings Dortmund
D-IBBS German Private Jet Group
D-IRKE German Private Jet Group
D-CBBS German Private Jet Group
UP-EM008 Comlux KZ
HB-JSF Scintilla AG/Bosch
HB-JSG Scintilla AG/Bosch
Morning Ingo
Nothing yet on D-FFUN but other added
