0 Members and 26 Guests are viewing this topic.
#13920
Thanks again Terry,  I presume that these are from EC.  I also not that while they are shown as Global Jet they fly using the registration as flight ID and don't use a Global Jet flight ID.  An example is M-AAAL on this time and even showing the ALM logo.  Guess its something used to get round the RVSM requirements.
Despite hundreds of aircraft showing on eurocontrol as IGA not one IGA flight ID is showing on the network
Yes Terry, the Chelsea owner
CarlosAbreu
11-02-2018 Updated file in attach.
Yesterday I rebuilt all my 1st floor Ecoflex 10 cable instalation and all connectors where verified in detail.
The best range at this moment is around 60 NM, amplifier is working but later I'll check values. However after this "check up" I think that low range problem doesn't have nothing to do with my equipment.
Probably I'm dealing with a new physical obstacle somewhere or a radio interference because in summer my maximum range was 160 NM and actually meteo conditions are good, parcial cloudy but no rain.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Thanks Carlos,  how is it without the amp?
CarlosAbreu
Very poor without amp, no more than 2 NM
Carlos
Oh dear Carlos, not good!!
CarlosAbreu
#13926
Very strange indeed, however as amp is working fine now I can pick up flights until 70 NM (better than nothing) but this still a mistery to me because there's no more visual problems with equipment, "N" connectors were correctly assembled and mass cable (that was missed in last time) is plugged in the correct way, if it wasn't I coudn't pick up any flight (I suppose) !!!
Before 2nd equipment crash after over cable cut when I thought problem was solved my range was 133,79 NM.
There must be something hided somewhere that is blocking my full range, the only change I made was the replacement of one original old "N" solded conector from my Wimo antena by one not solded supplied by SSB too.
If low range persist I will try to replace the old "N" connector...who knows it solve the problem ?
Carlos
Give your antenna a good look into as well, make sure no water has entered it.
CarlosAbreu
Thanks for sugestion, I'll do it so soon as I can.
Carlos
Evening Terry
Executive Flight Operations is the corporate flight department of The Boeing Company based in Gary, Indiana. EFO operates four Challengers and three BBJ 737s to fly the company's executives around the world.
As these are different from the normal Boeings Company ones in the database, these ones are for internal company flights as opposed to Boeing airliners on test flights, returned from airlines or getting ready to go to airlines I have entered them in the d/b as Boeing Executive Flight Operations
Good morning Alan, Tuesdays unknowns:
3D05CF  DEALJ (2x)  no further information
3D5899  DFFUN still nothing
MILs:
* 3EB00F  GAF523                                                         2018/02/13 07:14:58
* 3EB00F  GAF523                                                         2018/02/13 15:19:02
* 3F4EF1        2018/02/13 11:28:44
* 3F7709  SPOOK1                                                         2018/02/13 07:12:26
* 3F9D34  SMASH12                                                        2018/02/13 18:35:37
* 3F9D34  SMASH12                                                        2018/02/13 19:38:10
48DEE9  SPYYK all I found is this cockpit picture: http://www.alpina-avia.ru/wp-content/uploads/2014/09/06.jpg
Regards Ingo
Carlos,
the amp itself could have been damaged too. If it starts producing more "noise" it will have bad impact on reception range and messages received.
What types of N-connectors are you using. I once had a contact problem with the inner conductor inside the N-connector.
Morning Ingo
Mil tac added
48DEE9,SP-YYK,801610,Yakovlev Yak-50
Nothing on the other two
superspotter
Greetings from Lagos;
Hexcode 0641C5 is 5N-BRW S-76 of Bristows Nigeria, regards clive.
Afternoon Alan,
AFL2621 : LEMG-UUEE
AFL2620 : UUEE-LEMG
RYR21SR : EIDW-LEAL
