0 Members and 45 Guests are viewing this topic.
M
CSN449   ZGGG   EHAM
CSN450   EHAM   ZGGG
TOM386   ESSA   VCBI
TOM387   VCBI   ESSA
NTJ21K   ESOK   ESSA
NTJ28K   ESSA   ESOK
FIN7031   EFHK   EFKE   via EFKK
FIN7032   EFKE   EFHK   via EFKK
CLX977   ZHCC   ELLX   via UNNT
4620DA , OH-MLM , T206 , Cessna T206H Stationair TC , Support Group Oy , T20608538
Morning Alan,
Currently on a test flight out of Seville with full ADSB : EC-441 Airbus A330-243MRTT.
Morning Ian,  I have no idea which c/n is currently using the test code
Alan,
That makes 2 of us. According to FR24, it originally took off from Marseille and is wandering back and forth around Almeria.
CarlosAbreu
Do you know if there's any diference in use of N connectors soldered and non-soldered ?
All my connectors are from SSB (WiMo) however due to bad state of the original one from antenna cable (10 years weather exposure) I plugged a new one in the Ecoflex cable but non soldered.
Please advise.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Sorry Carlos I have no idea.  As long as they are correctly fitted I am sure that it will be OK.
CarlosAbreu
That's what I think too...
I'm going to call a friend of mine, a ex-Lieutenant from Portugues Air Force electronics specialist to get some advise in this problema that I can't understand !!!
Carlos
Are you 100% sure that the box is OK Carlos
CarlosAbreu
Yes, I still have other ANRB (same model) from a friend here, both tested with same result.
I spoke with two electronic engineers and told them conections were all checked several times but antenna low range persists. They said electronic interference like a new local telecom antenna or changes in frequency map are a strong possibility.
Carlos
Evening Terry
Some typos
N105T is a PA18
N286SZ is not allocated
9K-AOA is a B722 with Kuwait Airlines
Looks like you need to insert a filter Carlos
CarlosAbreu
A filter seems a good idea, a few time ago I tested a prototype for ANRB but it didn't work well. I'll try to get another one.
Carlos
Thanks Terry, all sorted
CarlosAbreu
16-02-2018 Updated file in attach.
Carlos
