0 Members and 21 Guests are viewing this topic.
hunter2021
0EA3D4
V3-HHB
GA8 Airvan
GA8-07-122
Tropic Air Limited
hunter2021
0AB003
V3-HHK
Cessna 208B Grand Caravan
208B-2249
Tropic Air Limited
hunter2021
0AB005
V3-HHM
Cessna 208B Caravan I
208B-2322
Tropic Air Limited
Evening Terry
Avia = Air so I have added it as Edelweiss Avia/VipJet  Edelweiss Air came to light in the Paradise Papers
Driving racing cars cars for a living means you can afford a BBJ
Good morning Alan, Sundays unknowns:
3E9D2C  GAF047
TRA5963 HV5963  EHEH EKCH
Regards Ingo
Morning Terry
I have made the changes again and please note I will require to re-do all changes I have made to the aircraft table over the last 3 or 4 days once Airnav restore the aircraft table back to its original state, hopefully later today.
Also please note that the likes of M-KBBG are not part of the Empire Aviation Group fleet.  They only manage it for the owner and it will probably not fly on an MJE flight ID and it will be the same for M-YBBJ which is not part of the EJME fleet.  This way the aircraft and its owners meet RVSM requirements with the management company being responsible for compliance but may also in some cases get some use of the aircraft when the owner does not require it in return for a reduction in their fees.
#13988
I have no idea Terry I can only presume that technically it may or may not be correct so therefore there may or may be no problem with it.  Its just that you made reference to the rest of the fleet when mentioning M-KBBG and technically it is not be part of the fleet.  If you look at http://www.empireaviation.com/index.php?/aircraft/fleet you will note that there are no Gulfstreams mentioned however http://www.empireaviation.com/index.php?/flight_operations may indicate that it is supported by them
CarlosAbreu
18-02-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
CarlosAbreu
My antenna range still very poor, around 80 NM.
This weekend I tested ANRB without extension cable directly connected to the main cable that comes directly from antenna and situation is the same.
So we can get a conclusion, problem isn't in extension Ecoflex 10 cable, it comes from main instalation.
This evening I'm going to apply again old conector with re-solded pin because last range with this one was 133 NM.
Keep you informed.
Carlos
I wasn't suggesting that at all Terry and have no problem with your suggestion.
Afternoon Alan,
Last week of the current TLP at Albecete and believe it or not a new one picked up today :
MM62293 G550 Italian AF with flight id 'PERSE01'. Circling just north of the airfield with full ADSB. It is in the d/b and I can confirm that it is still miscoding using 738A67 instead of 33FDC2.
ISS7420 : GCFV-LIPX
ISS7421 : LIPX-GCFV
Afternoon Ian, nice to get something new.  I saw it on earlier heading up north
