0 Members and 14 Guests are viewing this topic.
CarlosAbreu
19-02-2018 Updated file in attach.
Range problem still on, this afternoon old original solded N conector was tested but with same results, no better range. Due to situation non-soldered N conector was replaced and I'm going to buy a new one as soon as possible to exclude doubts.
In a later second option I'll buy from SSB the original 8m cable from my WiMo antena with factory cable solded conectors.
This mistery range problem must be solved !!!
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good morning Alan, Mondays unknowns:
0D0AC8  VIV8410  https://xfw-spotter.blogspot.de/2017/11/a320-271n-vivaaerobus-d-axao-xa-msn-8027.html
MILs:
* 3EB2C1  GAF640                                                         2018/02/19 09:29:30
* 3EB2C1  GAF640                                                         2018/02/19 15:56:25
   3F4047        2018/02/19 15:17:49
   3F4047  KNIGHT                                                         2018/02/19 19:14:54
* 3F61FE        2018/02/19 15:19:23
* 3F7422  SPARK1                                                         2018/02/19 08:28:29
* 3F7422        2018/02/19 17:24:47
* 3F8B49  JUDGE2                                                         2018/02/19 08:05:14
3FF4E9  DMHCY  still no luck with the details
48C5C1  SPSOB  Only info I got is http://www.helicopter-database.de/open.photo.php?idphoto=13600
Regards Ingo
Morning Ingo
0D0AC8,XA-VAY,8027,Airbus A320-232,VivaAeroBus
48C5C1,SP-SOB,1215,SOCATA TBM 910
Mil tac added and nothing on D-MHCY either
Carlos,
Check out your antenna, you have checked the box itself, the cable and its connectors
CarlosAbreu
Maybe I can acess the roof today in order to check antena.
Carlos
There may be water inside it, check for that and if so dry it out then re-seal it
CarlosAbreu
I'll do it, thanks for advise.
Carlos
CarlosAbreu
Roof operation is finish, antenna and connections are ok, no problema detected.
However in line of view to West, I found a new building construction with a big metal crane. This obstacle is very nearly to my house, around 100m. I don't know if it can cause any interference (?).
Anyway I have talk with Airnav Staff and so soon as possible I'm going to test a new antenna cables and connectors in order to identify this strange problem.
Carlos
That crane certainly wont help your reception Carlos
CarlosAbreu
That's what I suspected...!!!
The crane is going to be presente for months...!!!
I'm going to test other antenna but with this new situation results will be always conditioned by crane's presence. Only when she move out I can be  100% sure about this problem.
Carlos
Michel
Alan,
EZY41ZP LIRF-EHAM
KLM1948 EPKK-EHAM
Michel
Thanks again Terry
All Etihad Airways.  Although they carry cargo instead of passengers they are all operated by the same airline and use the same flight ID.  Not separate like Lufthansa Cargo and Lufthansa
Good morning Alan, Tuesdays unknowns:
3CF495  DCTXT no further information
3D27D3  DENIH (2x) was and possibly still is a Diamond DA20 A1 Katana
MILs:
* 3EB808  BARON72                                                        2018/02/20 08:23:37
* 3EB808        2018/02/20 09:39:53
* 3EB808        2018/02/20 13:12:53
* 3EB808        2018/02/20 13:46:40
   3F4047  NITRO16                                                        2018/02/20 07:40:20
   3F4047  NITRO16                                                        2018/02/20 09:56:29
* 3F8F20  SEAL                                                           2018/02/20 09:10:25
* 3FA00D  BARON71                                                        2018/02/20 08:23:32
* 3FA00D        2018/02/20 09:39:53
* 3FA00D        2018/02/20 13:12:44
458D35  DNU901 HEX matches https://www.planespotters.net/hex/458D35
Regards Ingo
