0 Members and 21 Guests are viewing this topic.
Afternoon Terry, thanks again
BOM1
Hi Alan
Some updates,
896344 in the database as A6-FOX EC30  4013 is now with Falcon Aviation Services as A6-FLT.
89600A in the database as A6-FLI EC30 4257 is in fact A6-FLY same operator
8961F9 in the database as A6-FLY EC30 4463 is A6-FLI also with FAS.
Steve
X
Another infuriating Russian issue. Only a couple of weeks back RA-97020 was photographed at ZIA in full Alrosa c/s. Today No prefix 97020 has been photographed in Russianplanes.net in new Red Wings c/s but who knows if it is the same c/n 95183 but both use the same hex. Repaint or new frame. russianplanes have the same c/n but is that correct????
Time will tell
X
Hi Steve
Can you advise if A6-FLT is using 896344 please
Many thanks
X
* 704010  MMA001   WMKK-VYYY                                             2020/06/22 17:07:38
X
X
704010,XY-ALN,2446,Airbus A319-111,Myanmar Airways International
CarlosAbreu
Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
BOM1
Hi Alan
Yes, sorry, should have clarified, A6-FLT is using 896344.
Steve
X
#20576
ffa
I see you wrote about this unknown miscode a few years back and decodes to RA-40055 but did you come to any firm conclusion as to what uses it. I have it with c/s RA85563 many times which is an Air Force Tu-154 which should use 154E3B
   149C77        2020/06/23 09:46:25
   149C77        2020/06/23 10:25:17
X
X
#20577
* 180BE9  RA3049G                                                               2020/06/23 10:47:12
Flying at around 10000ft at 162 mph from near DME (Podolsk?) eastwards. russiaplanes.net have RA-3049G as a Colibri-33 which I can find little about :( Eurocopter???
X
Morning Terry, thanks again
