0 Members and 99 Guests are viewing this topic.
M
JTG927   EFHK   LBBG
JTG928   LBBG   EFHK
TAY436M   EBLG   EETN   via ESSA
71C060  HL8060  A321  Airbus A321-231  Asiana Airlines  7133
Morning Alan,
VOE2260 : LFRS-LEAL
EXS302 : LEAL-EGAA
EXS301 : EGAA-LEAL
HAT151 : LIPE-LEZL
TDR298 : LEZL-LOWW
juliomb179
#6032
Hi Alan:
FC8104 SKBO-SKMR
Correct AV9A293  to AVA9293
Correct ARE3055 SKBO-SLCL to SKBO-SKCL
Julio
#6033
Good Afternoon/Evening Alan, unknowns from Monday:
1405F0 https://planefinder.net/data/aircraft/RA-01520
3C4A09 nothing more
3CE139  DCMPD might be ex. D-IMPD according to: https://forum.luftfahrtclubbraunschweig.de/viewtopic.php?t=4789&p=40495
3E32A6  DIKUM in 2015: Cessna T303 Crusader http://www.skybird-ev.de/visitors/s15----d.html
3FF2F4  DMRUB still no luck with the details
3FF425  DMORU no further information
406DEB nothing more
43EA25 no active/valid airframe found
47BCFC nothing  more
4CA2F6 no active/valid airframe found
71C060  AAR860D Posted by M, but just in case: http://xfw-spotter.blogspot.de/2016/05/a321-231sl-asiana-airlines-d-avxh.html
802200 nothing  more
EA03C2 no country allocation
MILs:
* 3E928F  NOBLE                                                          2016/05/30 09:58:57
* 3EA234  BOMBER                                                         2016/05/30 13:09:53
* 3EAD50  APOLLO1                                                        2016/05/30 08:20:48
* 3F4514        2016/05/30 09:10:06
* 3F4514        2016/05/30 13:25:36
* 3F5042  GAF120                                                         2016/05/30 06:11:32
* 3F5042  GAF120                                                         2016/05/30 08:07:40
* 3F6908        2016/05/30 12:06:33
* 3F6B25  LANCE1                                                         2016/05/30 07:38:52
* 3F6B25        2016/05/30 13:47:10
* 3FB7B0  STONE2                                                         2016/05/30 09:09:34
* 3FBCA9        2016/05/30 09:45:59
Regards Ingo
Many thanks Julio.  I can find AV9A293 but can confirm AVA9293 is in the d/b
Good evening Ingo,
1405F0,RA-01520,1220,Piaggio P-180 Avanti II
3CE139,D-CMPD,BY-249,Beech 250GT Super King Air, should be destined for Armed Forces of Malta after MPA refit
3E32A6 decodes to D-IKJM,  3E33C4,D-IKUM,T30300134,Cessna T303 Crusader,Scott Boylan so guess that it is miscoded
71C060 added in from M
3DEBE8,D-HJOY,0781,Robinson R44 Raven
3FF337,D-MPSV,,AutoGyro MTOsport
Nothing on the others and mil tac done
Many thanks
I got it twice with the hex 3E32A6. About 4 hours between the two receptions. So from my point of view I would say miscoded indeed.
Thanks Ingo, it is in with both hex codes
Let's hope that there isn't a  D-IKJM around outthere.
juliomb179
Hi Alan, another one:
ARE3147 SKSM-SKBO
Julio
