0 Members and 81 Guests are viewing this topic.
paul tricker
Despite the nationality of the codes, these are all ground equipment at Beijing PEK
49AAAA  sqawked 7777 24hrs a day for a week
76ED46  TXLU05
76ED47  TXLU06
also
7BF068 & 78C6D3 were eyeballed as Y-7's but were not near enough to read off  :-(
Is there any pattern to the Chinese codes? I have a lot of unknowns, some are dross, but others I'm not sure about
Paul
Hi Paul
The Chinese hex codes do not run in any sequence that I can make out, you can see that from Boeing's or Airbuses coming out the factories and the hex codes can be very different.
I can find nothing on your Y-7's
paul tricker
Thanks Alan, I feared that was the case.
Paul
Afternoon Alan,
Bit confused over ACA679 which is on 'My Flights'. It shows the flight ID as EC-JZR with the registration as 5B-CLP. It does state this is a miscode and also gives the type as an Aquila AT01 with c/n AT01-183.
However, the Spanish register is showing EC-JZR as a DA-42 Diamond Twin Star c/n 42178 and it gives it as current.
Incidentally, D-KDSD the glider would appear to be back. It has just come on !
#6020
Hi Ian,
No need to be confused.  It is just another miscode using the same hex.  It was actually AC6A79 and it decodes to N9.  I will change the existing entry to show it is in use by more than one aircraft.
Cheers Alan.
You know me , easily confused !
Good Afternoon Alan, further unknowns from Sunday:
005DB6 no country allocation
3CC2D4 nothing more
3D6873 nothing more
3E1D98  DICKE Beech 200 King Air http://swag-trip-logs.blogspot.de/2016/04/180416-stuttgart-augsburg-munich.html
3E2905 nothing more
3E8920 (Germany MIL)
C01072 nothing more
Regards Ingo
Afternoon Ingo,
3E1D98,D-ICKE,,Beech B200 Super King Air no c/n available
The mil tac added and nothing on the others
AoD
EXS898   LHBP - EGCC
EXS921D   EGCC - LTBS
GMI2804   EDDC - LGRP
WZZ372   LIRA - LKPR
company update:
49D08B,   OK-WOW,   Premysl Vodicka
paul tricker
These two were around yesterday
A395EF  N330BG                                                         2016/05/30 13:41:08
A395EF  N330BG  Dornier 328-200   3184   Heidi Aviation LLC
A6AE37  N53BK                                                          2016/05/30 09:50:55
A6AE37  N53BK   Augusta 109E   11769  Arena Aviation Group Inc Trustee
paul
Thanks again Paul
A395EF,N330BG,3184,Dornier 328-310 Envoy,Heidi Aviation
A6AE37,N53BK,11769,AgustaWestland AW109E Power,Bank of Utah Trustee
Liviu/All
4A09A3,YR-BMC,28822/166,Boeing 737-85F,Blue Air
4A09A4,YR-BMD,28826/283,Boeing 737-85F,Blue Air
4A09A7,YR-BMG,30231/515,Boeing 737-86N,Blue Air
