0 Members and 110 Guests are viewing this topic.
X
Two new ones in the area
    504E23  MSB6120                                                       2016/06/01 05:57:17
    504E37  PAX100                                                         2016/06/01 07:25:50
X
X
504E23,ER-IBI,1013409303,Ilyushin IL-76TD,Air Stork
Nothing on 504e37
Morning Alan,
IBK5322 : LEAL-ENGM
JAF74P : GMMX-LEML
And from yesterday and not populating :
345145
Flight ID : CASA954
(As a coincidence there is a Portuguese CASA295 (497CAA) in the air this morning using flight ID CASA956).
M
SVR841   USSS   EKCH
SVR842   EKCH   USSS
SVR839   USSS   EFHK
SVR840   EFHK   USSS
SAS17D   ESSA   ESMS
SAS16G   ESMS   ESSA
FIN588   EFKE   EFHK
LBT808   DTMB   ULLI
LBT809   ULLI   DTMB
KTK7887   ULLI   LBWN
KTK7888   LBWN   ULLI
MTL305   EVRA   ESSA
A3E541 / N350ER / B350 / Beechcraft B300 King Air 350ER / Textron Aviation / FL-1046
Thanks again Ian.
Nothing on what is using 345145.  Last time it was used it was on an A340.
The Portuguese is in the d/b so guess it has been in Seville for some work.
juliomb179
Same as yesterday, correct AV9A293  to AVA9293 (See attach image)
Julio
#6053
Hi Julio,
AVA9293 is correct in the database.  It looks to me like the flight ID has been loaded into the FMS of the aircraft incorrectly. We can only display what the aircraft is showing.
AVA9293,AV9A293,SKBO,SKNV,,
AV9A293 is not in the database
Many thanks
Goog Afternoon/Evening Alan, unknowns from Tuesday:
0008DA  NHPPCC H no country allocation, I wonder were this one came from...
38029F nothing more
3C0A53  SXD1064 D-ASXQ B738 https://www.flickr.com/photos/joe_balloo/18364366103
3C5356  TUI949   http://www.airfleets.net/ficheapp/plane-b737ng-32904.htm
3C630E at three different times, nothing more
3C70B1  BCS001Z http://www.airfleets.net/ficheapp/plane-b757-26332.htm
3E1E09  DICON no further information
3FF427  DMVGT no luck with the details
4008F5 no active airframe found
440821 nothing more
478375 no active airframe found
478430  LNOPE no further information
49518A was CS-TLJ I don't if it still is.
   49D283  TVS3BC                                                         2016/05/31 18:38:33
   49D283  TVS4BC                                                         2016/05/31 22:13:00
http://www.airfleets.net/ficheapp/plane-b737ng-30724.htm
4CA501 no active airframe found
4CC4EF nothing more
600BCC nothing more
A4F56A http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N41889  (maybe not, but it's valid)
A8C4DC not assigned or reserved
A968C8 not assigned or reserved
ABAB94 not assigned or reserved
AC30ED not assigend or reserved
MILs:
* 3E8084  GAF512                                                         2016/05/31 06:40:21
* 3E95CA  GAF063                                                         2016/05/31 09:12:08
* 3E9BF3        2016/05/31 10:30:45
* 3F5635  TIGER                                                          2016/05/31 07:48:21
* 3F8052  SEAL                                                           2016/05/31 06:18:44
* 3F8052  SEAL                                                           2016/05/31 13:50:45
* 3F978E        2016/05/31 13:19:55
The better coverage does indeed produce more work...
Regards Ingo
Two unknowns from Heidelberg Area (today)
* 3E6139  DKCAB http://www.flugzeugbilder.de/show.php?id=1382752
* 3F987B  (Germany MIL)
Evening Ingo,
3C0A53  SXD1064 decodes to D-ASXQ as you state.  The photo was taken April last year so would expect to find something on it but nothing found
3C5356,D-ADZV,32904/1302,Boeing 737-804,TUIfly first flight with TUIfly ex SE-DZV
3C630E decodes to D-AHXN, possible corrupt packet
3C70B1,D-ALEQ,26332/688,Boeing 757-2Q8,EAT Leipzig
478430  LN-OPE was an AS50 which became N624KS unaware if hex/registration has been reallocated
49518A was CS-TLJ, now N427PE
49D283,OK-TVY,30724/2286,Boeing 737-8Q8,Travel Service Airlines returned from lease to Air Transat
A4F56A,N41889,119,Erco 415-C Ercoupe,Zach Bair
3E6139,D-KCAB,4820,Scheibe SF 25 B Falke
Nothing on the others and mil tac added
Many thanks
juliomb179
QT844 SBEG-SKBO
Julio.
M
BLX377   ESSA   LGZA
BLX378   LGZA   ESSA
RLU283   ULLI   ENGM
RLU284   ENGM   ULLI
SDM6677   ULLI   LIPR
SDM5790   LGKO   ULLI
SVR5085   ULLI   LGRP
SVR5086   LGRP   ULLI
NWS7647   ULLI   DTTJ
NWS7648   DTTJ   ULLI
KTK7857   ULLI   LEPA
KTK7858   LEPA   ULLI
JTG975   EFHK   LDSP
JTG976   LDSP   EFHK
4677F8 is Ground Transmitter (not Ground Vehicle)
