0 Members and 77 Guests are viewing this topic.
Many thanks Ian
Regarding RCH1008 I have rechecked the server, there are no RCH flights on the database.  I have checked my Navdata there are no RCH flights in it so I have no idea where you have got this from.  Can you check your routes table and tell me if you have RCH flights showing please.
Nothing on your two ultralights
Hi Ingo,
3FF2A9,D-MIEW,,Pipistrel Virus
Mil tac added
Many thanks
Alan,
I have checked my routes table and RCH1008 does indeed appear with the route given as BIKF-CYYT and the date shown as 18th July 2012 !
Very strange. Without trawling through the full table, is there a way of eliminating any others that come up or I am  better waiting until your next visit for you to sort out ?
As to the 2 unknowns, Planefinder is giving OK-MUU as an Aerospool Dynamic WT-9 with a c/n of DY198/2007. However, they show the hex code as 49C00D and not 49C002 as AN showed.
FR24 are showing F-JAIU as a Alpi Pioneer 300 Kite. Same hex code as AN but no c/n or further details. Currently showing up on their site as flying around Almeria (LEAM).
Hi Ian,
If you update the Navdata all tables the RCH routes will not be there.  Failing that I will fix it when I come out.
Regarding the ultralights, the Czech register does not have an OK-MUU.  Ultralights should be like 49C001 which is OK-KUU 88 and 49C003 OK-LUU 01.  49C00D is OK-MUU 54
F-JAIU is the pilots radio call sign and I have no idea which aircraft he/she is using
Cheers Alan,
Thought that might be the case with the French aircraft.
Now I am confused (easily done) regarding OK-MUU 54. Not on the Czech register but registration confirmed against hex code 49C00D. As I said AN have the hex as 49C002. Can you confirm if you have changed to 49C00D on the d/b assuming that is correct ?
49C00D is already in the d/b as OK-MUU 54.  OK-MUU is not an ultralight registration as it does not have the 2 numbers after the letters and while I stand to be corrected it has never been allocated from what I can see.
Ultralights don't show on the Czech online register, I use my d/b and https://www.kmitocty.cz/?p=806 for the ultralights, these are confirmed against sightings by Czech spotters.
CYYZGUY
#6711
VRD167
No Routing
http://flightaware.com/live/flight/VRD167
WJA602
No Routing
http://flightaware.com/live/flight/WJA602
WJA477
No Routing
http://flightaware.com/live/flight/WJA477
C034FB  Nothing else...
An odd one here missing some info..
Mode-S 5000C0 Flight ID T7LRW
regards,
Jason
40" LED Monitor
40" LED Monitor
Hi Jason,
Many thanks again.
Its been in the d/b for a couple of weeks
5000C0,T7-LRW,9315,Bombardier BD-700-1A11 Global 5000,Reignwood Group/TAG Aviation Asia
Good Morning Alan, unknowns Aug 5th:
3E60A1  DKBUF Scheibe Falke SF 25C http://www.flugplatz-renneritz.de/main/index.php/verein/flugzeugpark
MIL: 3E8242  HG01B
3FF401  DMGAE still no luck with the details
3FF4E1  DMROF Roko NG6 UL http://www.english-for-flyaways.de/displayimage.php?pid=5779
3FF51B  DMHDT no further information
4400C9  OEVDB posted by M: 4400C9 / OE-VDB / DA42 / Diamond DA 42 Twin Star / Diamond Aircraft Industries / 42.004, still nothing at austro control
48DEE5  SPYYF http://www.airliners.net/photo/Untitled-%28Yak-Team-Wuemme%29/Yakovlev-%28Bacau%29-Yak-52/2816988
reagards Ingo
Good morning Ingo
3E60A1,D-KBUF,44557,Scheibe SF 25 C Rotax Falke
3FF4E1,D-MROF,6P040303K,Roko Aero NG 6,
48DEE5,SP-YYF,899404,Yakovlev Yak-52
OE-VDB added in following the post from M
Mil tac added and nothing on the others
Many thanks
OE-VDB didn't populate. Could you check if it's in the db correctly please?
Many thanks!
Try it now Ingo, should be OK now
Confirming, that all formerly unknowns have populated know.
jacobite
Hi Alan, HELP please if you can. I have now updated to windows 10.1 but I cannot use ANRB as there is no drivers available for the software. The windows 8 drivers do not work. Has anybody else had this problem?
X
#6719
This is the 6th time in three years I have picked this USAF 'unknown' up. Always flying between 19000 and 21000 (C130 height) sometimes on RCH/Reach flights others like below on ROSTM c/s. I had it as being 74-1677 Currently 74-677 with the Afghan Air Force.
   AE0312  ROSTM77                                                        2016/08/06 10:43:39
X
