0 Members and 30 Guests are viewing this topic.
Alan,
the problem will only occur if you try to install the drivers under a completely new installed WIN 10 aniversary (WIN10.1) installation. As Windows 10 aniversary will block all unsigned drivers. Although installed they just don't load anymore. If you have an already existing installation of an older WIN10 version, the aniversary update won't (or better shouldn't) cause any trouble, as the "unsigned driver blocking" isn't -for now- activated in these versions.
Hi again Jason
E48363 is a Brazilian hex hence the reason it is showing a Brazilian flag.  Its was last used by PP-PJC which is now C-FXJC so it looks like it is miscode its former hex code at least on one box
CYYZGUY
Thanks for everthing Alan as always....very knowledgeable.
3 more unknows...
C05015  Flight ID CGEIM  Nothing else
C000E5 nothing else
A16B84 nothing else
I am starting to see a lot more regional flights showing up with ADS-B now, it is a good sign as 2020 gets closer in North America...
40" LED Monitor
40" LED Monitor
No idea which version of Win 10 is on my new laptop, as I state I bought it earlier this year.  As I advised contact with Airnav is the only way to be assisted as us users can do nothing to assist and that advice still stands.
Thanks again Ingo
48C4A2,SP-SFC,40006,Lancair 300 LC-40-550FG
Jason,
C05015,C-GIEM,28-7911160,Piper PA-28-236 Dakota,Straitline Contracting
C000E5,CF-AIU,75-2180,Boeing PT-17 Kaydet,Canadian Warplane Heritage Museum
A16B84,N1907M,560-6201,Cessna 560XL Citation XLS+,Meijer Distribution
Many thanks
correct, Airnav should be contacted as our user support is always limited at some point.
Just for info: Aniversary update came out past tuesday if I remeber correctly, so I'm very sure, that you have installed WIN10 and not WIN10.1 / WIN10 aniversary edition. In WIN10 all is fine. In WIN10.1 all should be fine, if drivers were successfully installed under WIN10 prior to the update to WIN10.1. That's what I could figure out so far.
For all who are using PC only for running ANRB.EXE 24/7 there is a way to totally disable automatic updates (background sub-process of WIN update completely dead). I did this on my 24/7 server PC.
Thanks for the info INGO, I guess its the bog standard WIN10 on my machine
falcon_nl
#6744
List from a couple of days:
4B1C35, HB-KRT, 2331, HUSK, Aviat A-1B Husky
3E7968, D-KLEE, 5076, RF5, Fournier RF-5
3FED2B, D-MDHW, ECHO, Tecnam P92 Echo JS
484EEC, PH-4H9, 338-772, RENE, Murphy Renegade Spirit, M.G.L. Albers
3D769F callsign DFRED
3FECEA callsign DMENC
3FF3AF callsign DMTLR
3D7AA5 callsign DFSRT (saw it 16 times in 2 days)
3FF418 callsign DMKLU
miscode
222222 callsign DMAXG
#6749
falcon,
3D769F,D-FRED,20800293,Cessna 208 Caravan
3FECEA,D-MENC,049,Aerostyle Breeze
3FF418,D-MKLU,C42-0079,Ikarus C42B
3D7AA5,D-FRST,,Cessna 208 Caravan
3FF3AF,D-MTLR,,AutoGyro MT-03
Forgot this one 222222,D-MAXG,012-087,B & F Funk FK-12 Comet,(Miscode)
Nothing on the others
Many thanks
