0 Members and 27 Guests are viewing this topic.
falcon_nl
Evening Alan,
EZY16HX : LELC-EGKK
KRF2414 : LEMD-LICA
RYR13YY : LEAL-EDDW
SAS4655 : ENZV-LEAL
VLG1177 : GCTS-LEVL
WZZ22VX : LEAL-LHBP
CYYZGUY
40" LED Monitor
40" LED Monitor
The ongoing OFF-Topic discussion about WIN10.1 and Classic Hardware drivers were commented by Airnav Support as following:
Quote from: AirNav SupportHi,
We are aware of the issue, background is basically Windows 10 had "softly" stopped unsigned drivers being used but it wasn't being enforced. However in there latest update:
"Windows 10, version 1607, the operating system will refuse to load any new kernel mode drivers that are not signed by the Windows Hardware Developer Center Dashboard portal, or Dev Portal. To be clear, new installations of this version of Windows 10 will enforce the new driver signing rule, whereas older versions of Windows 10 upgrading to 1607 will not be affected by the change"
This has only recently been announced and has caught many hardware developers out of the blue.
We will be getting the drivers certified and will keep everyone up to date on the progress. Apologies for the inconvenience caused.
Morning Ian,
Many thanks again however can you please confirm VLG1177 : GCTS-LEVL, destination is LEAL please
#6756
the past seven flights with flight id VLG1177 VY1177, on each Saturday since June 25th, were going from GCTS to LEVC
Many thanks Jason
C07D59,C-GVME,539,Chipmunk,Rick Ksander  Please note this is an amateur built aircraft and not the De Havilland Chipmunk
Morning Ingo
3D0F36,D-EEFM,275,Robin R 2160 Alpha Sport,
3D127E,D-EFGG,276,Robin HR 200-120B
3FED6D,D-MTTL,267,Remos GX
3FF4DD,D-MSWB,575,Tecnam P92 Echo 100S
4B4E5C,PH-1546,36819,Diamond HK36TTC Super Dimona,(Miscode hex of HB-2485)
Nothing on the others
Many thanks
Route Update:
DLH91A LH1176 EDDF LPPR
Morning Alan,
My mistake and as confirmed by Ingo, VLG1177 should be GCTS-LEVC. Not sure where LEVL came from. Possible touch of brain fatigue !
Now, here's one to get you working :
BAW2634 : EGKK-LEAL
That's ok but the return flight is given on the departures board at LEAL as BAW2635 but is shown on the arrivals board at EGKK as being BAW2633 !
Plus :
EIN1041 : LEAL-EGAC
Cheers Ian, no worries both BAW2633 and 2635 are already in the d/b as LEAL-EGLL
Route update:
DLH3ER LH104 is EDDF EDDM
