0 Members and 13 Guests are viewing this topic.
CYYZGUY
40" LED Monitor
40" LED Monitor
Hi AoD,
3FA8BA German mil tac code
400C6A,SP-APR,34-7970218,PiperPA-34-200T Seneca II,Extreme Fly (Miscode hex of G-GAFA)
Nothing on the others
Many thanks
Can you update any AIRPORTS in the database that have "(unassigned)" in the PS field.  There are about 300, and these cause the airport to display without any clue of the airports state or country.
By copying the PT field into the PS field for all airports with PS = "(unassigned)", these will then display correctly.
For example, Vagar airport on the Faroes displays like this:
Airports are in the database by City, State and Country.  The unassigned part regarding Vagar relates to the state in which it is situated.  As it isn't situated in a state due to the country size I have changed the unassigned to Faroe Islands and will be shown as such from tomorrows Navdata update.
The updater software only does aircraft and routes and therefore as I can only do these changes on an individual airport basis it may take some time.  I will need to look up unassigned in the Navdata and then make a PHP query direct to the server for each one and then make the change.
Good Evening the unknowns from Tuesday:
122F76 nothing more
3C4B48 nothing certain / some sources: D-ABZH ex. EI-DSL
3CB283 nothing more
3CD5AA nothing more
451DAF nothing more
47850E nothing more
4BAB32 nothing more
MILs:
* 3F63C1  HG01B                                                          2015/09/15 10:30:43
* 3F6BBC  GAF601                                                         2015/09/15 07:42:16
* 3F6BBC  GAF601                                                         2015/09/15 09:55:16
* 3F8123        2015/09/15 14:15:30
* 3FA810  GHOST                                                          2015/09/15 13:45:03
   3FA8BA  LK01B                                                          2015/09/15 08:29:49
Regards Ingo
Evening Ingo,
3C4B48 decodes to D-ABZH and is due to enter service ex EI-DSL but have not seen any evidence of delivery but made the change in the d/b.
Nothing on the others and mil tac added
hi checked the entry of  3C4B48 in MyLog.db.
One reception, during a time frame of 45minutes 63 mode s messages received. Altitude between FL15 and FL13.
So, decoding errors and reception of broken/damaged data packets can't be excluded.
The rest has populated.
Ingo, it was possibly on a flight test, EI-DSL was WFU from Alitalia 9th May.  Added to d/b.
CYYZGUY
40" LED Monitor
40" LED Monitor
Good Afternoon Alan, unknowns from Wednesday:
400780 nothing more
44B072 nothing more
484B06 was PH-IMR M20T, nothing about a new one using this REG/HEX
4BA9F4 nothing  more
76CD60 nothing more
9000C3 nothing more
B166CB no country allocation
MIL:
* 3E853C  GAF640                                                         2015/09/16 08:26:59
* 3E853C  GAF640                                                         2015/09/16 11:57:46
Not much to add to the db for you today.
Regards Ingo
Afternoon Ingo,
Nothing on any of those and the mil tac added.
Northern Watch
Good afternoon Alan
I picked up this anomaly whilst at Edinburgh Airport this morning.  43C2CD which the db has as G-BFIB miscoding.  The c/s was XZ725 and then 2 Lynx helicopters flew over, one of which had 337 on the door which I see is RN Lynx HMA.8 c/n 190.  The other, but not coding was 307, XZ694. Looks as if the Lynx is using the correct code.
Keith
Hi Keith,
It was one of a number of miscodes being used by G-BFIB while it was on Police surveillance missions that they didn't want us to know about and tried to hide its identity from us.
The Lynx appears to have been allocated it around about May so now updated in the d/b
43C2CD,XZ725,190,Westland Lynx HMA8SRU,UK - Navy
